536HP SD card in PC
dispatcher812
Connecticut
So, I now have my 536Hp in the truck. I have also been fine tuning my lists. Is there anything special that needs to be done to save my info to the SD card when I take it out of the scanner and bring it in? Do I just save it to the card from the "file" menu or do I "write to scanner"?
nr2d
Laurel Springs, NJ
I think I have seen each time I turn the scanner off it writes to the card. That's all I have done before removing the card and then making changes via Sentinel on my computer.
fxdscon
¯\_(ツ)_/¯
With card in PC, from Sentinel, write to scanner, just as if you were connected to the scanner itself.
