536HP speaker suggestions?
kg4usk
Looking for a decent mobile speaker for the 536hp. Any suggestions?
kg4usk
Cool thanks for the replies! I wasn't sure if I really needed an amplified speaker, but I'm sure it wouldn't hurt being in a mobile environment. I can look at the technical specs all day, but I do like to hear from some real world experience.
eaf1956
Evansville, IN
I don't think that an amplified speaker can be used with the 536HP. You might want to consult the manual or ask UPMAN.
Voyager
I use the Motorola non-amplified speakers, and I can turn the volume up high enough I wouldn't want to be in the same car, so I don't see a need for an amplified speaker. Also, the speaker output level may be enough to blow out the input of amplified speakers.
kg4usk
Thanks for the input!
I actually already own the amplified Uniden speaker (BC23A) for when I was using the '396xt.
I'm wondering though... IIRC the BC23A has a stereo 1/8 plug, but I'm assuming from what I see here, a speaker with a mono plug will work as well?
