6 meter ssb
sjm83651
Can anyone give me a recommendation for an easy to operate transceiver for 6 meter ssb? Thanks for your help!
hill
Middle River, MD
Most likely you will have to purchase an HF/6m radio, since don't think you will find any 6 meter radios. I know in the past some were made, but would be older models.
krokus
Southeastern Michigan
This will be simple to operate, but lacks some features that might be useful.
alcahuete
Southern California
Ranger used to make a 6 meter only mobile radio, if you can still find them used. They are fairly rare, but do come up from time to time on QRZ.
For any decent all-mode 6m radio, you're pretty much going to be stuck with a normal HF radio.
hill
Middle River, MD
Kenwood made the TS60 years ago, which is a 6 meter only rig. There is one on Ebay, but for the price of it's over $600 you could purchase a HF/6m radio for the same price or lower and have all the DX bands.
K4EET
Chaplain
Severn, Maryland, USA
Seeing that you hold a General class license, do you already have an HF rig that covers 80 through 10 Meters but lacks 6 Meters? Is that why you are looking for a standalone 6 Meter rig? As has already be said, most modern rigs are going to cover 160 through 6 Meters. If you don't have one, while a little more expensive, you will broaden your horizon immensely. The MFJ-9406X mentioned in Post #3 above is a good starter rig that will get you on 6 Meters and would be easy to use, however, you might be disappointed in the long run of not having better noise rejection features, lack of better metering and waterfall display, computer interface, etc. that a rig like the Yaesu FT-991A would give you for a street price of about $1,150. While that may sound like a lot of money, it covers:
RX 30 kHz - 56 MHz, 118 MHz - 164 MHz, 420 MHz - 470 MHz (specified performance, amateur bands only)
TX 1.8 MHz - 54 MHz, 144 MHz - 148 MHz, 430 MHz - 450 MHz (amateur bands only)
Not only do you have 160 to 6 Meter and 2 Meter / 70 Centimeter transmit and receive capability, you also have an excellent shortwave broadcast receiver. You'll spend $330 for MFJ's 6 Meter bare-bone transceiver so we have a $1,150-$330=$820 delta. If you had to buy a 146/440 MHz rig, you are looking at about $400 for a C4FM digital transceiver as the Yaesu FT-991A is capable of. So now the cost delta is down to $820-$400=$420. To get an HF rig for $420, it probably will not be modern.
Sooooooo... I don't know your situation but think this through and down the road before you buy anything. There is a lot out the and what you purchase today can last you for a very long time. Happy hunting!
73, Dave K4EET
WA8ZTZ
S.E. MI
If you want a new stand alone 6M SSB xcvr then AFAIK the MFJ 9406 is your only choice.
A bit pricey at over $300 but it comes easy to operate (no annoying menus or multifunction buttons) at no extra charge.
However, if you also want CW, you will need the optional CW module.
