7/800 Question
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
I am not asking for software here as I have all the necessary tools.
Today I went to create a codeplug to play around with the 7/800 features of the XTS5000 I'm planning on getting soon. I went to enter the 769/799 band plan frequencies (NAC types), and got bonked with the red square of errors!
So I went into hex-edit (XVI32 program) and tried to find the upper end of 851.06250 (minus the decimal), and the lower end of 806 something, and got nothing!
Does anyone know where the 7/800 band splits are located in CPS 20?
Regards,
-Frank C.
mikewazowski
Forums Manager
Oot and Aboot
Why would you need to hexedit anything?
The XTS5000 already covers everything you need in the 700/800MHz bands.
If you're getting red squares, you're doing something else wrong.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Regards,
-Frank C.
The band plan and NAC are not in any way related. NAC are 3 digit hex codes.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Disregard - my sample codeplug was not set up for the right trunk flavor.
Click on View>Invalid Fields to get descriptive information on why a "red square" is present.
kg6nlw
Jay, due to the frequency being invalid. The radio I'm planning on getting has the right model number to it, so I know that's not an issue.
Regards,
-Frank C.
kg6nlw
Seems as if CPS 20 doesn't cover the 769/799 band plan naturally, even though it should...The only thing I have done is entered in the frequency, example is CHP Amber in the Golden Gate Division 769.44375 / 799.44375 NAC DB3. Red square of invalid frequency appears.
Regards,
-Frank C.
talviar
Uniontown, PA
Regards,
-Frank C.
The better question- since there are so many spots you could be entering frequencies. . . . are u entering these under the zone/channel screen where u would normally enter a conventional channel?
Or are u entering these 700 MHz freqs elsewhere.
If elsewhere such as under trunking- the band plan information and set # needs entered in on the trunking tab as well as the band plan referenced when u enter the freq in for control channel.
I won't be near a computer until later tonight where I can pull up software and a codeplug to detail further. . . . .
KevinC
32D2T/957.282
I'm everywhere Focker!
Regards,
-Frank C.
Try entering 769.0125.
kg6nlw
Tony, I'm under Zone/Channel screen. This, thankfully, isn't my first XTS to program, just the first 7/800 split radio...
Regards,
-Frank C.
Jay911
Regards,
-Frank C.
According to the RRDB that is a conventional frequency not a trunked frequency, so "band plan" shouldn't be in the equation at all.
In order to set up a conventional ASTRO frequency, you have to have an ASTRO system created and a Conventional Personality created.
After you've done that, when you enter the conventional frequency in the Zone/Channel Assignment page, the frequency will show up as "invalid" if you have Tx Opt Transmit Dev set to 5.0 kHz (the default). Change it to 2.5 kHz.
kg6nlw
UPDATE - DOH!
A total Homer Simpson moment! I totally spaced and forget to set the narrow/wide requirement to 2.5Khz! Problem solved...I feel like such an idiot!
Thanks again everyone!
Regards,
-Frank C.
