996 Alert Indicator
kyarger
Bowling Green, Ohio
When is this supposed to light up? For weather alerts only? Mine does not come on for
channel alerts. Is there a problem with the scanner? Thanx for any input
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Hello,
The ALERT LED will illuminate after a WX Alert, or if you program a POI as a Dangerous Road or X-ing, and are within the Speed and Distance parameters set when using the BCD996T with a GPS. No, there is nothing wrong with your unit. :)
73
Dave AKA The Tripzter
This is a small test for the 396. I think it also works on the 996.
Turn your unit ON while holding the 0, 1 and 3 keys simultaneously.
TURN THE VOLUME DOWN FIRST!!!
See if your ALERT LED comes on.
kyarger
Bowling Green, Ohio
Thanx for the info and sorry for the delay in the return
Curiously, I also asked Uniden about this and they said it does not work on the 996 and that it is for a 'similar model?' But after re-reading their reply, I think they might have been referring to it's function in relation to the close call feature
kyarger
Bowling Green, Ohio
Thanx for the reply!
I tried it with the 996 and it showed me a screen with some sort of weather SAME test
No indicator lite
monitorman
I have the opposite problem the alert light on mine will not go out. :confused: Uniden's answer is to send it in for repair.
kyarger
Bowling Green, Ohio
Alert indicator
That's a bummer. I see you have two very nice old radios: the Kenwood R-5000 and the venerable Icom R-7000--wish I would have picked up one of each, back in the day, when they were available!
monitorman
Thanks, I still enjoy using them. :)
trunker0205
Rhode Island
Here is a simple test that will work to verify the indicators:
Turn "ON" your 996 while simultaneously holding keys 0, 1 and 9.
Press the Squelch button repeatedly.
Display will say key touch test Squech key push
Now push in Vol key Display color will change and the alert lamps will light.
"Alert" and "Close-Call" indicators will light
__________________
kyarger
Bowling Green, Ohio
They work!!!
__________________
Thanx for that handy tip! At least I know the lights are functional.
__________________
Good work!
