A Little Repeater Help
btritch
Paragould/Greene County AR
I'm looking to put an amateur repeater on the air in my area, I have a small budget I've looked at a few cheap repeaters, I wonder if anyone can recommend a good cheap repeater, I've looked at some Kenwood and some Vertex but they are commercial grade and i'm not sure how to make them identify, can anyone recommend a quick setup that will cover a small portion of my area?
ai8o
Brachiating Tetrapod
Lexington, NC
Are you near Bentonville?
The Walton Foundation sometimes gives grants to local "non-profit community groups".
Your radio club may qualify as a local public service group.
Doesn't hurt to ask.
russbrill
Sacramento, CA
Where do you plan on installing this repeater??? Private Residence or Commercial Tower Site???
The Kenwood repeaters can all be programmed to send out a CW ID at a set interval. Any reputable repeater will be able to do this since it's required by the FCC.
If you can find a good used one, that would be an option.
If you are looking for new, while I'm not a big fan, the Bridgecom repeaters are a good starting place. A little more geared towards amateur/GMRS use. Pretty much plug-n-play, down to the point that you can send them your frequencies/tones and they'll program the repeater and tune the small flatpack duplexer that can be installed inside. Add power and a decent antenna and you are on the air.
vagrant
ker-muhj-uhn
California
Here’s what I did:
$400 - Yaesu refurbished repeater DR1X from Yaesu you easily program via touchscreen and they ID
$100 - UHF mobile duplexer (notch filter) via eBay, some will tune it as well
$100 - UHF antenna I cut/tuned to my TX freq
$??? - LDF4-50A coax
Plus, some N patch cables between the repeater and duplexer, and another from the duplexer to the LDF4-50A coax as it is rather rigid. I also upgraded the repeater N panel connectors to silver.
When I first got things going I was using LMR-400 and a dual band antenna. Changing to the better coax and single band antenna I tuned for my TX freq made a big difference. Some fine people here on RR clued me in about the coaxial cable concern for repeaters. Another tool that helped me was an inexpensive VNA. I used it when cutting the antenna as well as fine tune the mobile duplexer. This system is used at my home location. At a high RF site I would use a BpBr (Bandpass/Band reject) duplexer.
Please note the Yaesu should be limited to 20W on UHF, but you could use an amplifier. While the Yaesu will deliver 50W, repeaters with a high duty cycle failed due to the heat. In a climate controlled environment, it may be fine at 50. Both I and a friend have ran ours at 50, but our duty cycle is low.
btritch
I'm actually clear across the state from that area, that's good to know though
btritch
Hmmm
btritch
Here’s what I did:
Good information right there!
AK9R
Staff member
Super Moderator
Central Indiana
Also, you should contact the repeater frequency coordinator for your area to get a coordinated repeater pair.
prcguy
I found the power supply in my Yaesu DR-2X repeater was near 14V and I turned it down to 12.0V and it lowered the 50W down to 40w and it runs ok at high power. I put a temp probe on the transmitter heatsink and I don't see a problem with higher duty cycles.
Not sure how well a mobile duplexer will work with that type repeater at 40w, you might need more isolation.
Here’s what I did:
vagrant
ker-muhj-uhn
California
That is good to know for the DR-2X. I'm thinking of getting another DR1X, so I may take a look that and do the same. I may also pop a fan on top of the heatsink if it will fit.
As to the mobile duplexer at 40 or 50 watts, it worked for me, but not all mobile duplexers are the same. I am getting at least 70dB isolation on each side and just over 1dB of loss when checked using an HP spectrum analyzer. Still, I did not perform extensive range testing at 50W. Truly they are not a BpBr filter, so one gets what one pays for. In my reasonably low RF environment, the mobile duplexer I have works fine. If I went with say a Motorola UHF BpBr duplexer, I'm looking at 3dB loss. In that scenario I would use a small amplifier to compensate and run the Yaesu at 5W.
russbrill
Sacramento, CA
That's still up in the air, we could go either way, most likely residentual but commercial is an option
Commercial sites can be really strict about equipment.. I'd talk to a few other Hams that already have repeaters at the sites you're thinking about to get an idea about requirements.. Good Luck..
73,
Russ
