Hahahaha I know about LCN's but not LSN's.You will learn all about LCN's and LSN's in the next session![]()
| Site RAN: | (* Any) |
OK not sure how to deal with this one, but looking at the coverage map I might be in range of this one. So if I wanted to set this one up I could just LEAVE OUT the RAN#? I did find a DMR system that is HUGE and covers a lot of area. But I will wait till tomorrow or later to ask questions about how to go about setting the files up for that. It looks like DMR doesnt use "RAN" numbers. Some sites dont have control channels either.It's telling you the 'neighbor' sites on the RAN. You have to edit the DSD.frequencies file for that one to but not necessary. Especially if you're outside of reception range.
I caught my mistake and changed the whole post to "Good Question"OK not sure how to deal with this one, but looking at the coverage map I might be in range of this one. So if I wanted to set this one up I could just LEAVE OUT the RAN#? I did find a DMR system that is HUGE and covers a lot of area. But I will wait till tomorrow or later to ask questions about how to go about setting the files up for that. It looks like DMR doesnt use "RAN" numbers. Some sites dont have control channels either.
Haha I tried to set it up but got errors in RED in the event log about "missing fields"(* Any) = RAN Search
it is not known, So it's basically a blank or placeholder until a specific RAN can be verified, in Trunked systems the RAN is generally the same as the Site Number 1,2,3
BearCom RDC Trunk Trunking System, Various, Multi-State
BearCom RDC Trunk Trunking System Profilewww.radioreference.com
RR calls it "System ID".I dont see anything about "network ID" in the screen shots I posted.....I can see everything but Network ID. The instruction in the "Trunking.txt" file TELLS you WHAT to do but not HOW to do it! If there is no "Network ID" to be found what do I do?
Show your work...Haha I tried to set it up but got errors in RED in the event log about "missing fields"
OK Thanks for that very helpful info....got the 1R batch file all edited. I made a batch file to start the whole thing but I know its full 'o errors. Take a look at it here:RR calls it "System ID".
Re your PM'd questions - The changes you're making via the DSD+ menus aren't "sticking" because you're using a batch file that always requests other settings. I assume you're left clicking on the 1R.bat file to run DSD+ (which is the right way to do it). If so, right click on 1R.bat and select Edit. That should open up the file in Notepad. If you don't want per-call audio recordings, delete the -Pwav text. To block log file generation, delete the >>1R-log.txt text. -E only applies to log files, so it can go as well. To block writing to the big DSDPlus.wav file, add -O NUL
Your final result should look something like this:
DSDPlus -r1 -T -i20001 -O NUL
Save your changes and close Notepad. Delete the DSDPlus.wav/.srt files, the 1R-log.txt file and the 1R-Record folder.
I deleted all the editing but I will try again and post errors......the errors referred to missing fields in certain lines of the files I edited. Here is the system: RDC Communications - Network 178 Trunking System, Various, Multi-State - Scanner FrequenciesShow your work...
Probably because you started a copy of cmd.exe and it's just sitting there waiting for you to tell it what to do.OK Thanks for that very helpful info....got the 1R batch file all edited. I made a batch file to start the whole thing but I know its full 'o errors. Take a look at it here:
@Echo off
start %SystemRoot%\system32\cmd.exe
cd dsdfree
start 1R
start FMP24-CC
@Echo on
exit /s
The "exit /s" is supposed to make the CMD screen turn off after file runs but it doesnt.
The networks file doesn't deal with sites or site numbers. It wants the network ID (178), not a site number.I deleted all the editing but I will try again and post errors......the errors referred to missing fields in certain lines of the files I edited. Here is the system: RDC Communications - Network 178 Trunking System, Various, Multi-State - Scanner Frequencies
The SITE I want is "009 Fall River"
The Fall River site data is here: Fall River Site Details (RDC Communications - Network 178)
Again, I am thinking the missing "RAN" caused problem, but I did substitute the site number, 9 in the lines in both "Networks" and "Sites" files in DSD folder. This is the line I used: NEXEDGE48, 9, "Fall River" in "SITES" & "SITELOADER" files and NEXEDGE48, 9, RDC Communications in the "Networks" file.
Frequencies put in the freq files. I can try to assemble it again and see what happens.
OK I got it, I deleted @ Echo and the cmd.exe line now works perfectly! Been 20+ years since I did DOS batch files.....forgot all that stuff.Probably because you started a copy of cmd.exe and it's just sitting there waiting for you to tell it what to do.
The echo on/off doesn't do anything useful either.
I redid the data for this system and still error in "Event log" saying "No channel data found for NEXEDGE site 178-1 Fall River". But I had a number missing and fixed it so it is working.The networks file doesn't deal with sites or site numbers. It wants the network ID (178), not a site number.
None of the files care about RAN.
