This request currently applies to those people who:
Unfortunately, this cannot be a How-To. So I'm counting on only those people who meet the minimum requirements to reply.
My request is this... I suspect one or more sites in Southern Ohio have changed to a new zone. As such, I'd like to get updated information regarding the System ID and Site ID of the following sites:
SUGAR GROVE (HOCKING)
NELSONVILLE (HOCKING)
SOUTH BLOOMINGVILLE (HOCKING) - especially this site
UNION FURNACE (VINTON)
MACARTHUR (VINTON)
JUNCTION CITY (PERRY)
LANCASTER (FAIRFIELD)
CIRCLEVILLE (PICKAWAY)
LONDONDERRY (ROSS)
CHILLICOTHE (ROSS)
If you are simply going to plug in the primary control channel for a site and then let us know what the System ID and Site ID are, then that should be simple enough.
If you are going to run a trunking program (some variant of Trunker, Trunk88, TrePort, Unitrunker), then please only do this with a pristine copy (not your normal one that you use that is already populated with old information). You should only provide information for sites that you can reliably monitor. If the site's control channel is on the fringe and you aren'et able to get 100% decode, please do not post any info for that site.
For those that may be able to run a trunking program, it would be handy to know:
a. System ID
b. Site ID
c. any frequencies that show up active including primary / alternate CCs
d. Site Neighbors (it'll list the site ID of the Site Neighbors)
If you are not familiar with performing these tasks, please do not respond. Instead, if you are interested in learning how to determine this information but do not currently know how, you should do some reading on the RadioReference Wiki with regard to using trunking programs.
NOTE: If a site's System ID or Site ID do not match up with what is listed in RR, don't get confused. Look at the Site Alias and match that up to what is listed in RR. If a site has been changed to a different zone, it's site ID won't be the same as the one listed in the RRDB either. An example is South Bloomingville (Hocking), whichc I believe no longer has the System ID of 6F10 and likely no longer has the Site ID of 62. But you'd still know it was South Bloomingville based upon the Site Alias that is reported on the scanner or in the trunking program.
Thanks for any help that you can provide. Feel free to post here [I guess]. Feel free to PM me or email me if you have a lot of information. Acctually, it's probably best to submit any findings that you feel are 100% correct via the Submit button on the DB page for MARCS -- Ohio MARCS - Multi-Agency Radio Communications Trunking System, Statewide, Multi-State - Scanner Frequencies
Thanks for your help, folks!
Mike
- 1. Have a digital scanner and monitor MARCS
- 2. Live in HOCKING, VINTON, PERRY, ROSS, PICKAWAY or FAIRFIELD counties
- 3. Understand enough about their scanners to obtain System ID and Site ID information by parking on a control channel
and optionally:
- 4. Have a trunking program configured to work with their current scanner and are able to monitor the control channel of various MARCS sites to obtain System ID, Site ID, frequency, and Neighbor information
MACARTHUR (VINTON)
LONDONDERRY (ROSS)
CHILLICOTHE (ROSS)
a. System ID
b. Site ID
Mike
