Action Communications LTR
vgabnd
Everett, WA
Anyone know the home channels etc. for programming the Action Communications LTR system? I have the freqs from Intercept Northwest, just curious how to actually program them into a Motorola Radio.
vgabnd
Everett, WA
I believe he said a Motorola Radio not a scanner.
That is correct. I Picked up an HT-1250 LS from another member here and would like to experiment with programming something other than simplex and ham stuff. Any info would be appreciated!
AtomicTaco
Isn't there an option in the RSS to specify a LCN for each freq? That's all I have to do for my Icom LTR radios.
vgabnd
Everett, WA
This is a screen shot from CPS. I can't find anything matching LCN.
AtomicTaco
In the top left shot, the left column of numbers--if it only goes to 20 then that's probably your LCN. You'd probably get a better answer in the Motorola forum.
DickH
LCN? Please clarify...
Logical Channel Number means that each freq. must go into a specific channel.
EDACS has the same requirement and in the RR database the channels are small numbers in front of each freq. Some channels may be left empty. For example, the freqs. might be in channels 01, 02, 05, 09, 10, 11, 12, 16.
