Ada County / BLM fire freqs
PaulSWIdaho
Boise
I overheard Ada county fire dispatch tell some units to go to TAC-7 for a fire south of the airport. But I don't find a TAC-7 frequency listed anywhere. I'm finding TAC-1 through 6, but no 7. Any suggestions? thanks in advance :)
thewenk
Idaho DB Admin
Eastern Idaho
Are you referring to BLM conventional frequencies or Ada County Digital Talk groups?
Ada Fire 7 Is TG 1406 on the ICAWIN Digital System.
There are a lot of Talk groups listed for Ada Count Fire.
PaulSWIdaho
Boise
Thanks for your response @thewenk.
I understand your question but I don't know the answer. I have heard BLM talking to Ada county fire on 155.385 FM. But from there they usually move to a "TAC-x" channel. RadioReferrence has the TAC channels listed up to 6, but not 7.
Now that I've been thinking about my original question I should change my question: I live in Hidden Springs (Ada county). What I really want to do is to get ONLY fire dispatch from the Hidden Spring fire station, that would be Eagle Station 3. I do not have an APCO 25 receiver so this is a problem. If I was to get an APCO 25 receiver would it be possible to configure for just this? I'm showing my naivety about APCO 25 with this question I realize. Any short description appreciated.
thewenk
Idaho DB Admin
Eastern Idaho
Yes, There is likely a VHF frequency for TAC 7. You could program all of the Fire VHF frequencies listed for Ada Cnty fire into your scanner and see if any of them happens to be in use as TAC 7. You might get lucky.
I would not spend the money on a digital scanner. All stations are usually dispatched on one frequency or TG in the case of digital (but not always).
Hopefully someone in the Boise area can help answer your question.
MountainMoose
All Things radio
Ada County, Idaho
You would need a P25 capable scanner. The SDS100/200 are ideal. Unfortunately most all of the FD are dispatched out of Ada county dispatch which also does: So, you could program via Sentinel just those Talkgroups. So yes essentially it is possible to program only a limited number of TGs etc, BUT those TGs also include many other FD and you would need to know and listen for those Station 3 Eagle unit #s.
rectanglehead808
Caldwell, ID
Tac-7 is a vhf frequency of 154.3850.
In Ada's 700 radios it's called zone Bravo. BLM and other agencies have this zone in BK radios and apx 7000/8000s.
