ADSBexchange - new map display in testing
stlouisx50
Mountain Grove, MO (Texas County)
Two apps that uses ADSBexchange data.
OpenADSB iPhone and iPad app.
• Comes preconfigured using ADS-B Exchange data.
• Configurable to show military and interesting aircraft only or both.
or
ADSB Flight Tracker app (uses ADSBexchange data)
For users with android smartphones.
Freedar.uk
These apps uses data from ADSBhub.org
PlaneMapper.com uses data from ADSBhub.org
(iOS app will come out around April,2020)
Thanks, works great!
campd715
Southeastern Connecticut
I like the new map layout. Not sure where or how to post this request so I'm putting here in the hope that those with the magic coding finger will see it.
This is in reference to the UNITS options in the setting (round cog wheel). It defaults to Aeronautical but I would prefer Imperial. Might it be possible for the program to remember the end user's selection?
Dennis
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Dennis
The map has nothing to do with anybody here. You need to post on the Home - Serving the Flight Tracking Enthusiast - ADS-B Exchange forums.
Mike
MtnBiker2005
San Diego County, California
wiedehopf
Hey there, great so many of you like the new map.
It started as a modification of the dump1090-fa webinterface, but obviously has evolved quite a bit.
The history function hasn't been mentioned here explicitely, when you click on history in the aircraft details on the left, you can check past flights of the same airframe.
The track labels (K) work extremely well with that, you can also cycle through the legs the aircraft flew that day (detection is a heuristic, so it's not perfect).
Similar using the gear wheel menu you can toggle being shown 24h of trail when clicking a plane, or only showing the current flight since last takeoff (heuristic again).
I've read the remark about saving Imperial/Metric/Aeronautical, i'll check that :)
And before someone remarks that, the columns on the right and the labels need customization, i've been dreading to program that but i think i might have some good ideas.
phask
zanesville
All I can say is THANKS.
Only thing I miss is the owner info. (or maybe I'm missing a setting)
wiedehopf
Some database stuff is still in the works.
Not sure if the owner info is part of what's being worked on. (But it's a common request)
storm777
Tacoma WA
@wiedehopf , thank you for your hard work on this. I confess, at first I wrestled with my "resistance to change", but that soon passed. It's given me great pleasure during this period of quarantine & I look forward to what refinements the future brings.
MtnBiker2005
Make customs quick links to save on your smartphone / browsers.
Map Help
https://www.adsbexchange.com/map-help/
Military only aircraft
https://tar1090.adsbexchange.com/?mil
Airport - Loads map to that airport location
tar1090 - https://tar1090.adsbexchange.com/?airport=jfk - (JFK)
tar1090 - https://tar1090.adsbexchange.com/?airport=adw - (Andrews AFB)
tar1090 - https://tar1090.adsbexchange.com/?airport=aff - USAF Academy Colorado Springs)
tar1090 - https://tar1090.adsbexchange.com/?airport=tik - (Tinker AFB (Oklahoma)
Lat/Lon - Centers map at location.
https://tar1090.adsbexchange.com/?lat=38.123&lon=-98.123
If you want to clear the location you can use the following Parameter:
https://tar1090.adsbexchange.com/?SiteClear
Range Rings can be turned on and off in the Map Layers Icon, there is no way to adjust the ranges displayed.
Andrews Air Force Base - (Location & Range Rings)
https://tar1090.adsbexchange.com/?SiteLat=38.809&SiteLon=-76.867
Tinker AFB (Oklahoma) - (Location & Range Rings)
https://tar1090.adsbexchange.com/?SiteLat=35.415&SiteLon=-97.386
Air Force Academy (Colorado) - (Location & Range Rings)
https://tar1090.adsbexchange.com/?SiteLat=38.972&SiteLon=-104.819
icaoFilter=hex1,hex2,hex3 – Displays only the listed planes:
82-8000 - B742 (Boeing VC-25A) (Air Force One) - ADFDF8
https://tar1090.adsbexchange.com/?icaoFilter=ADFDF8
92-9000 - B742 (Boeing VC-25A) (Air Force One) - ADFDF9
https://tar1090.adsbexchange.com/?icaoFilter=ADFDF9
Both aircraft only on the map: tar1090 - https://tar1090.adsbexchange.com/?icaoFilter=ADFDF8,ADFDF9
Performance Graphs
https://tar1090.adsbexchange.com/graphs1090/
MLAT sync stats for ADSBExchange regions
http://adsbx.org/sync/
North-Western US (inc. AK), Western Canada
https://adsbexchange.com/coverage-1A/
South-Western US (incl. HI)
https://adsbexchange.com/coverage-1B/
North-Eastern US, Eastern Canada
https://adsbexchange.com/coverage-2A/
South-Eastern US, South America
https://adsbexchange.com/coverage-2B/
Military/Interesting
@MtnBiker2005 does the link above show both interesting and military? I know there isn't a lot of traffic tonight but I was not seeing any interesting aircraft, only military, I'll try tomorrow again, but just curious.
This is a great addition and I greatly appreciate the hard work of many that went into it.
campd715
Wouldn't it be nice if all the above links from #33 could be placed in one convenient place such as their own button or in a drop down menu on the new Adsbexchange map. Just a thought for the coders involved with this wonderful project.
Stay safe everyone
Dennis
There is one convenient place that you can access all the URls, customized exactly how you like them and with your location, all mine are kept there. It's the BOOKMARK section of your browser, enter in the term you give the bookmark and there it is, how convenient, and doesn't make more work for the over worked coders.
cg
Connecticut
Couldn't the same could be said for every option that is available on the display? Someone must have thought having those things on the page was worth it.
chris
The problem is, most of the URLs above contain generic info that you customize, such as lat/long, aircraft icao filters, airport codes, ring size. The one that is consistent already has a button, military (U button). But perhaps a help page link, rather than it's own URL, with an explanation on how to set your own customized URLs would be helpful?
cg
Connecticut
Just thinking back to the old ADS-BExchange page where there was a bunch more choices in the option window that would add many of those things. Having the ability to add/remove another filter without saving a new URL would seem much more efficient.
Not a complaint over how it is, just seems like having to save pages with the options selected is a bit clunky to me.
chris
@MtnBiker2005 I have a feature request to add through URL or filter, and that is for Species. Currently I'm helping with a project where I need to look at just helicopters across the US, but can't figure out how to do that without zooming in to a limited area.
Thanks for considering this.
