Advice needed
baloumax
Edmundston nb
Looking for scanner looking at sds-100 but in the 700 mhz it goes low at 758 from what i see on uniden page
I was told in my area edmundston nb i would miss some stuff with upcoming new tmr for police etc told i would need something in the 720 range
So any other scanner i should look at
And is there any truth to this
CT
Here are the Specifications on frequency coverage.
Not sure about Canada, but here is the 700MHz band in US
marksmith
Anne Arundel County, MD
No
tvengr
Well Known Member
Baltimore County, MD
What is your source for the frequencies? I cannot locate any info about a tmr system in Canada using frequencies that low.
baloumax
Edmundston nb
Its in nbtmr and some parts are not active yet for edmundston region
It is to come that they might use in the 720s so just tryin ti spend the money on something that goes there
mikewazowski
Staff member
Forums Manager
Oot and Aboot
720MHz is a cellular band in Canada. You won't find any public safety systems in that band.
Bell Mobility Cellular owns the rights to two blocks of spectrum covering that frequency area in the Maritimes.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
No, that area is strictly cellular. I don't believe ISED set aside any 700MHz spectrum for private companies.
Whoever told you they would be using 720MHz for TMR is wrong. Most likely they'll use the spectrum set aside for public safety by ISED which most newer scanners cover.
