AFRN Programming Question
arturobandini
Is AFRN P25? Auto? Manual? Something else? Trying to program a Pro-651 and not having any luck. I put in the freqs and then the BFD talk group: nothing.
arturobandini
Bloody Hell. Any recommendations for a replacement or a website that will help me choose? I can't spend a lot.
chill30240
West Georgia
Personally I use the BCD436HP. If simulcast is not a problem where you are then that will work fine. Otherwise if simulcast is a problem then you will need a SDS100. I just bought another 436 after Christmas from Bearcat Warehouse for $429.00. The SDS 100 is $649.00.
arturobandini
Thank you. I confess, as a novice, I don't understand simulcast being problem. At those prices it's a low priority for me right now. Sad about all of this, though. Rude awakening.
chill30240
West Georgia
chill30240
West Georgia
It's sad because back in the day we had crystal controlled scanners and everything worked fine. Now everything is so computer controlled and encrypted is costing an arm and a leg to continue the hobby.
chill30240
West Georgia
jefferson county is phase 1
I was under the impression that it was all Phase II since all the sites in Jefferson County only showed N/A for the site modulation. I usually listen to Opelika and they are P25 Phase 2 TDMA . The main page for the Alabama First Responder Network shows :
System Name:Alabama First Responder Network
County:Statewide
System Type:Project 25 Phase II
System Voice:APCO-25 Common Air Interface Exclusive
Last Updated:January 8, 2020, 7:15 am ((1) Talkgroups Updated (Jefferson County - Trafford))
I stand corrected. Then the Pro-651 should be able to pick it up.
radiopro52
North Alabama
The system is capable of Phase II but most of the talkgroups seem to still be phase I. I know all the talkgroups here in Morgan and Madison counties are phase I. When I was vacationing down in the gulf a couple of weeks ago they were using Phase II.
tvengr
Well Known Member
Baltimore County, MD
I have an ARC500 file for Jefferson Co. At the time I did it, Jefferson Co was operating Phase 1. I can't check right now. The Radio Reference database is down. I can easily convert the file to WIN500 if you prefer that. The system type is P25 Auto.
tvengr
Well Known Member
Now that the database is back up, I see that Jefferson County is still phase 1 which your scanner can receive.
