AFRRCS - Alberta First Responders' Radio Communication System - Updates
Taber, Alberta Canada.
A few times recently I have heard what sounds like a police surveillance operation on TG 6405.
Has anyone else noticed?
I'm also hearing police surveillance activity on this channel and it seems they are working in Picture Butte right now. I am wondering if it’s possible that it could be Alberta Law Enforcement Response Team (ALERT) using this channel.
avgas
Alberta
I am hearing what sounds like Park Rangers or Fish and Wildlife on 3143. They are talking about campers in the Beaver Mines and Castle Falls area. I have heard the same dispatcher talk about a traffic stop on the #1 Highway. I am only hearing one side of the conversation, so its pretty hard to figure out whom it may be.
harryshute
Edmonton, Alberta, CANADA
3143 is the All Call/Fleet Call for Alberta Parks in the South. They have the Dispatch PRCC/ESO in the clear. You should see Agency 403 UID's when they transmit.
I get this group in Edmonton perhaps because PRCC is here.
Once PRCC makes contact with a CO or Conservation Officer on their local PRCC group the call is dispatched.
Hi guys
It's your neighbor from next door, you know, Saskatchewan.
I have several of questions for you guys.
1. Where are the dynamic regroups (patches) to be found in your data base? Your P25 system must utilize them.
2. Do you guys ever see anything like what is seen in my Unitrunker screenshot?
These are 3 link-radio IDs seen in use on the PPSTN.
There are several more like these in use.
We suspect that at least 3 others similar to these may be used to link the PPSTN to the AFRRCS.
When these patches are in use only the one RID is ever seen on the talk-group, as it is a link-radio connected to another link-radio on the other radio network, so those RIDs are never seen.
Your assistance in this matter will be greatly appreciated.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Hi guys
I would guess that the networks are linked via ISSI.
As for link radios back to back, what are they linking to?
Using back to back radios would be an incredibly stupid way to tie an AFRRCS talkgroup to a PPSTN talkgroup.
harryshute
Hi guys
Don't think we have patch groups in the database. I've never logged them but from what I know they are SAID or Supergroups. They are in the 620XX range with 62097 as an example.
I've often wondered about the patches to Saskatchewan. With the RCMP I see four UID's when patched two for the Edmonton dispatch center and two for the Red Deer OCC.
RCMP K NAOCC 1 UID 4448000
RCMP K NAOCC 2 UID 4448001
RCMP K SAOCC 1 UID 4448002
RCMP K SAOCC 2 UID 4448003
Is PPSTN as Harris or Motorola System? AFRRCS is a Harris System.
Hi
The PPSTN is a Harris system.
I thought that the two systems both being Harris would most certainly be linked via the Harris IP network and not with old fashioned link radios that are used to link the PPSTN to the Manitoba Motorola system.
Two link radios are also used to connect RPS and RFD to the PPSTN.
From what I have seen so far Harris Super-group patches will usually begin with the HEX A4, as all 99 in use on the PPSTN do.
I am hoping that one of you guys running a trunker program will share when a SG patch is seen like the ones in the screenshot.
If patches are seen in use simultaneously on both systems that would be exactly what I would like to see.
Cheers
Hi, all
The attached zip file contains all of the super-group IDs that I believe are utilized by the AFRRCS.
Please have a look at it.
Cheers!
  • AFFRCS Supergroups.zip
kayn1n32008
Sector 001
Hi
It should absolutely be possible to link them by IP, even if it's through the ISSI protocol. AFRRCS and the city of Calgary(Motorola) systems are linked via ISSI.
My guess is, laziness to be using subscriber radios to link these networks.
I can't for the life of me understand why they would do this. The P25 spec has methods to link separate systems with out resorting to subscribers to facilitate it.
R_Rabbit10
If someone could add the following to the database:
Stettler Regional Fire
6752SRFD DISPATCH*Stettler Regional Fire Dispatch
6752 PageSRFD STN 1/2/3/4 PAGE*Stettler Regional Fire Page Station 1/2/3/4
6753SRFD TAC 1*Stettler Regional Fire Tac 1
6754SRFD TAC 2*Stettler Regional Fire Tac 2
6755SRFD TAC 3*Stettler Regional Fire Tac 3
6756SRFD OPSStettler Regional Fire Operations
6757SRFD TAC 4Stettler Regional Fire Tac 4
6758SRFD TAC 5Stettler Regional Fire Tac 5
6759SRFD TAC 6Stettler Regional Fire Tac 6
6760SRFD TrainingStettler Regional Fire Training
6761SREMA EOCStettler Regional Emergency Management Agency Emergency Operations Centre
6762SREMA OPS1Stettler Regional Emergency Management Agency Operations 1
6763SREMA OPS2Stettler Regional Emergency Management Agency Operations 2
6764SREMA PLNG1Stettler Regional Emergency Management Agency Planning Section 1
6765SREMA PLNG2Stettler Regional Emergency Management Agency Planning Section 2
6766SREMA LOGS1Stettler Regional Emergency Management Agency Logistics Section 1
6767SREMA LOGS2Stettler Regional Emergency Management Agency Logistics Section 2
*)Monitored by dispatch
Kneehill County
5339​
Acme FireAcme Fire
5340​
Carbon FireCarbon Fire
5341​
Linden FireLinden Fire
5342​
Three Hills FireThree Hills Fire
5343​
Torrington FireTorrington Fire
5344​
Throchu FireThrochu Fire
5345​
KC Tac1Kneehill County Tac 1
5346​
KC Tac2Kneehill County Tac 2
5347​
KC Tac3Kneehill County Tac 3
5350​
KC Tac4Kneehill County Tac 4
5351​
KC Tac5Kneehill County Tac 5
5352​
KC ICP1Kneehill County Incident Command Post 1
5353​
KC IPC2Kneehill County Incident Command Post 2
5354​
KC TrainingKneehill County Training
5355​
KC LOGS1Kneehill County Logistics Section 1
5356​
KC LOGS2Kneehill County Logistics Section 2
5357​
KC PLANKneehill County Planning Section
Morinville
2396​
AnnounceMorinville Announce - Only Fire Channels
2398​
Morinville CPOMorinville CPO Channel
2399​
Morinville TrafficMorinville Traffic Channel
2400​
Morinville DispatchMorinville Fire Dispatch Channel
2401​
Morinville Working 1Morinville Working Channel 1
2402​
Morinville Mutual AidMorinville Mutual Aid Channel
2403​
Morinville Working 2Morinville Working Channel 2
2404​
Morinville Working 3Morinville Working Channel 3
Sturgeon County Emergency Services
5278​
Sturgeon Working Channel 10Sturgeon County Working Channel 10
5279​
Sturgeon Working Channel 9Sturgeon County Working Channel 9
5280​
Sturgeon Working Channel 8Sturgeon County Working Channel 8
5297​
Station 1 Calahoo DispatchStation 1 Calahoo Dispatch Channel
5758​
Station 6 Gibbons DispatchStation 6 Gibbons Dispatch Channel
6248​
Sturgeon Working 21Sturgeon County Working Channel 21
6249​
Station 3 Legal DispatchStation 3 Legal Dispatch Channel
6250​
Station 4 Namao DispatchStation 4 Namao Dispatch Channel - For Future
6251​
Station 5 Bon Accord DispatchStation 5 Bon Accord Dispatch Channel
6252​
Sturgeon Working 22Sturgeon County Working Channel 22
6253​
Station 7 Redwater DispatchStation 7 Redwater Dispatch Channel
Gibbons Fire
5758​
Main / Dispatch ChannelGibbons Main Dispatch Channel
5759​
Gibbons Working 1Gibbons Working Channel 1
5760​
Gibbons Working 2Gibbons Working Channel 2
5761​
Gibbons Mutual AidGibbons Mutual Aid Channel
NRCAER
4580​
NRCAERNRCAER MA - Fort Saskachewan City
St Albert
4498​
St Alberta FireSt Albert City Fire Services Shared
Penhold
6642Penhold Dispatch
6643Penhold TAC1
6644Penhold TAC2
6645Penhold TAC3
6646Penhold TAC4
harryshute
I enjoyed the postings of the new Lacombe County Fire groups in the database.
Have Clive or Eckville gone live? My guess and just a guess. Clive Fire Dispatch 5088, Tac 1 5089 and Tac 2 5090. Eckville Dispatch 5091, Tac 1 5092 and Tac 2 5093. I have a logging on 5094 not sure if it's in the mix.
I know Blackfalds and Sylvan Lake are now on AFFRCS. Is the City of Lacombe and Bashaw Fire?
Cortexian
If there were more than three AFRRCS nodes on the Calls Platform we might know!
