I've been a scanner junkie for years and very recently decided to get into the SDR scene so I bought two of the cheap $20 RTL-SDR dongles from RTL-SDR.com and was able to get them working in SDRTrunk. I've learned a lot about these and how they work by reading the forums here and through Google searching. I primarily listen to our local 800Mhz P25 phase 1 county services (LE/Fire/EMS) and I've had good luck decoding our LSM/CQPSK using the two cheapies with SDRTrunk.
The system I am scanning spans about 6MHz (854.0425 to 859.9375) so I decided to pick up an Airspy R2 since it has the bandwidth to cover the entire 6MHz spectrum I want to scan. SDRTrunk has support for it so I assumed there would be no issues switching from the RTL-SDRs to the Airspy. Unfortunately, I'm not having much luck using the Airspy for decoding this system with the 10MHz sample rate selected. If I select the 2.5MHz sample rate it will track and decode the voice channels as expected but of course it doesn't cover the entire bandwidth so calls are dropped/not decoded. As soon as I switch back to 10MHz it tracks the entire spectrum and when I click on the control channel line I see under events each of the talk groups being decoded but I get no voice. I will occasionally get a bleep or a bloop (it sounds kind of like an '80s video game), similar to using my Pro-106 scanner which can't decode our simulcast correctly due to lack of CQPSK support. When I put the RTL-SDR dongles back in I get clear voice. Of course the sample rate for those is 2.4MHz.
My PC is an 8-core Xeon with 16Gb of RAM so system resources are not an issue. I've tried changing the Master Gain and using different USB ports as suggested by others but no luck. I've read where others have had issues with the Airspy R2 stating a defective TCXO chip but before I try to RMA this thing I want to make sure I'm not missing anything. I've run SDR# and I am able to hear the control channel for this system but only if I turn the GAIN to its highest level which is 21. If I tune to an FM broadcast channel in SDR# with the sample rate at 10MHz it's very distorted but as soon as I switch to 2.5MHz the broadcast is clear.
Am I missing a setting or something needed to make this work at 10MHz?
