kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Any idea why the provience is going to 700Mhz rather than vhf or uhf? would it not take less infrastructure to cover the provience with a vhf or uhf P25 system than a 700 mhz system?
Hi folks,
learned some things about the province-wide radio project today.
It is going to happen. No matter what you heard from your cousin's best friend's neighbor's gardener who happened to know somebody who unlocked the gate for the tech at tower site XYZ. This is well underway at this point.
The current descriptor is the Alberta First Responders' Radio Communications System, or AFRRCS. Don't expect that name to stick - I hear it's not very favored.I pronounce it "a-farks" but to each their own.
The driving force is the Alberta Office of the Solicitor General and Service Alberta (formerly Restructuring & Government Efficiency). They're handling it mainly because the two radio systems that need help the most - MDMRS and PACS - fall into their areas of control.
The timeline for total system completion is end of 2010 at the latest. The dates are still fuzzy, of course - things are still in the incipient phases, even if they are late in the incipient phases - but construction is scheduled to begin in October 2007 and take 3 years. Also, for what it's worth, the system is intended to last for 15 years from the time of deployment.
It will be 700MHz and will be P25. That is the standard that the provincial overseers are mandating in the tender/RFP/whatever you wish to call it.
There will be some encryption. Participants in the system are having their interests represented by filling out a "Needs Survey" in which they describe their communications requirements and interoperability issues. Encryption is offered at every turn in this survey.
We will likely see some sites roll out by the end of this year. The gist I am getting is that migration will be similar to how Ontario is doing it with ON FleetNet - in phases/zones. I would expect that larger areas may be developed first, with major transportation corridors following - because as I said, this is intended to first and foremost replace MDMRS and PACS, and MDMRS is all but on life support right now, and PACS reportedly can last just long enough for this new system to come online.
There is supposed to be a website set up shortly detailing the progress. I'm not sure if it's intended for public consumption or just the partner agencies involved in the system; as most of you know, I work with a couple of said partner agencies, so I have to be careful what exactly I pass around, so to speak. If information crosses me that is meant for the world to hear about, I'll contribute it.
The modern radios that are used on the Calgary Motorola Smartzone system can handle 700MHz P25 regardless of what vendor markets it, so long as they don't add weird proprietary extras like ESK, OpenSky, etc.
More info, as always, as it becomes available.......
There we are! It wasn't posted till this afternoon/evening.
The four vendors are mentioned in the RFP. They are, in alphabetical order:
Bell Mobility Inc.
General Dynamics Canada Ltd.
TELUS
(All four vendors are consortiums that include, besides the primary vendors, sub-contractors including radio manufacturers, network and infrastructure specialists, etc.)
The RFP will close at 2PM MST on February 18 2009.
