Q12
- Joined
- Sep 30, 2022
- Messages
- 12
Hello! I have alernator Whine issue on my Kenwood TK-790 Mobile Radio Setup.
The Vehicle Everything is in Is a Ford Expedition 2000.
I have it configured in a Dualband Setup with a TK-890. Both Radios Controlled with a Single Control Head.
The TK-790 Is Radio 2 in the setup and is Connected to a Kenwood Filter (KLF-2) and then to the Car battery with Fuses on both Positive and Negative.
Antenna Setup is an NMO with a Dualband Comet in the center of the roof.
Same thing with the 890 but a Magmount Antenna instead.
When I would Transmit on UHF with the 890 there is No Alternator Whine in my Transmission or Recieve Speaker.(It used to have it Untill I Ungrounded my Control Head and Problem Solved.)
But On the VHF Side, When I Transmit and Just receiving audio, I hear the whine and it correlates with my Engine RPM.
It goes away when I run the Car on Accessory Mode.
The 890 Is set-up with Ignition Sense and Gets the Ignition sense from the Control head with a Fused and Tapped Wire coming from the Fusebox.
Things Ive Tried already.
-Disconnecting the Mag Mount Antenna to make sure it's not That that's causing the Ground Loop.
-Grounding the Radios to the Cars Chassis.
-Using a Magmount Antenna for the VHF Radio.
-Removing the Ground from the Control Cables of the Radio 1 to Radio 2
-Setting up my Base TK-790 in place of my Mobile and no Whine when this happens.
I'm guessing it has to do with the Control Cable to Radio 1 that is causing a Ground Loop.
Any Help is Appreciated!
