Amplifier for hotspots?
S21IL
Dhaka, Bangladesh
Planning on getting a hotspot or a more DIY approach. But looking at the specs of them, the 10 mW Tx power seems to be a deal breaker. Looking to get enough power to go around a 500 metres or a kilometre at.max. any way to do that? I guess conventional amplifiers won't work due to tdma :s
Sent from my Redmi 4X using Tapatalk
djs13pa
Not sure but you might run into coordination issues running higher power. Have you maximized antenna and coax efficiency?
S21IL
Dhaka, Bangladesh
Didn't get one yet. Looking to explore my options before purchasing one. As sad as it gets, don't have a single amateur DMR repeater in the country leaving me no choice but to get a hotspot. But the TX power seems to be the limiting factor. Seems fairly pointless spending $500++ on a radio+hotspot if that doesn't get me past my shack :(
N2AL
Tennessee
I saw this YouTube video online. The amplifier is pretty stout so I would say you can turn the transmit power down to the needed range.
I hope this video helps!
https://youtu.be/nyaK6tN8i7w
djs13pa
If you won’t interfere then might work but I am not an expert on your nations coordination rules.
I’ve often thought about treating hotspots like microrepeaters. This would have a cellular phone structure covering an area. Reduces repeater costs and allows better coverage where people would use it.
prcguy
These amplifiers are designed for much greater power than what the hotspots put out and may not key up reliably. I also see the build quality of the Chinese amps is very questionable.
prcguy
N1GJB
Manchester, NH
Anyway to interface hotspots to a repeater?
What digital mode or modes are you attempting to interface to a repeater? That would determine exactly what option works best but likely the MMDVM would be your best bet (doesn't reliably do NXDN from what I understand but will run everything else).
Project25_MASTR
TX-COMU
Texas
Depending on whether or not the hotspot could do offsets it could simply be shotgunned but if not you'd have to setup the repeater for a simplex link.
To answer the OP's original question 500 meters is only 79 dB of path loss in the 70 cm band. 1 km would be 85 dB of loss. So RX signal would be between -70 dBm and -75 dBm if we are talking about being out in the open (which still leaves 35+ dB of link budget on even the worse subscribers).
S21IL
Dhaka, Bangladesh
I just need DMR
R8000
Very Low Battery
This is a really bad idea. The hotspot was intended to be just that, a hotspot. Not a wide area device. If you can even kludge an amplifier on to it, hotspots don't have all that great of a receiver. So you may be able to make it talk, but it may not hear you very well.
The other thing is, if you do find an amp, like someone else said, it will probably come from China and throw spurs and other IMD products all over the band which will piss off your frequency neighbors.
After all this trouble, in the long run you are better off to just put up a small repeater. You could use a MMDVM modem and a used commercial repeater. You could buy a used Motorola XPR series repeater and just "plug it in". The repeater doesn't need to be a powerhouse. 25 watts or less is all you will need.
S21IL
Dhaka, Bangladesh
This is the option I'll go for hopefully. As we don't have any DMR repeaters here in the country. Have it connected to the BrandMeister network maybe..
S21IL
Dhaka, Bangladesh
Going a bit off topic, how'd the hotspot run on mobile data? I mean would the latency introduce any issues with TDMA?
N2AL
Tennessee
I have never had issues. I used to run the internet connection from my cell phone but now I use my wifi connected to a RaspberryPi connected to the OpenSPOT.
According to my RaspberryPi it uses about 4GB per month. That is with constant use by the way. I cannot account for your situation but I doubt it would be too excessive.
Anyone else have some insight?
iceman977th
Mess with the Bull. Get the Horns.
Catlettsburg, KY
If you want wider coverage, build yourself a DMR repeater of some sort using a pair of mobile radios and a digital modem like the MM-DVM, if you can afford to have one shipped to your country (if they will do it). Here in the States, you can get cheap Motorola radios with a repeater interface cable on eBay for a decent price, then find a way to wire in the MMDVM to them, and you're off to the races.
S21IL
Dhaka, Bangladesh
That's the plan I've had. Can get the MMDVM, also the Motorola mobiles but stuck because I don't own the CPS, no one I know does and to top that off, we don't even have a dealer who could do it for me
jeepsandradios
East of the Mississippi
I installed a small fiberglass stick on my hot spot due to the fact its in by my cable router in my parents house a couple hundred feet from me. It seems to work well although im sure the loss factor is pretty good, but i have an sma adapter to the N(M) on the antenna. Works for me but YMMV
djs13pa
Get a couple of cheaper but reliable Connect System CS800s. The D model is dual band. The non D model is mono band (either VHF or UHZ). The nearest vendor might be in the UK but double check.
