Analog G5 tone alert with relay control
19sargeusmc56
I don't get it here. I have a G5 setup with a single, simple tone alert setup on an analog channel, WITH relay control and I'm getting tone alert with no relay closure.
I've tried 2 different charging cradles. I don't know what I'm missing here. Any constructive feedback would be appreciated.
Mboy00
Aberdeen Township
Do you have the relay set to a time?
19sargeusmc56
The accessory plug is 5 pins, and the diagram shows the white and yellow wires.....pins 2 and 3
ffexpCP
wizard of odd
Michigan
What firmware and PPS are you using? I just updated one from a old pps version to new 4.x, and 1.31 firmware to 1.34 and the relay control stopped working. I confirmed the setting is still correct.
brian86
Maryland
Any update on this? I am having the same issue after updating the PPS to 4.x and now the relay is not working on the accessory port. I have checked 5 amp chargers.
Hop763
Ky
There was a bug in the original 4 version of PPS that made the relays to stop working. You need to download the latest version to fix the issue. It’s a PPS issue not a firmware issue.
