BCD325P2/BCD996P2: Another BCD996p2 question
Falcon9h
Pretty much set up and going wityh the radio but one problem: audio dropouts on P25 transmissions where I miss whole words. At tyhe same time I notice that the P25 on the display disappears. Centre County, Pa. phase 1 system. (giving up on typos with this suckaxx keyboard with its phantom and douible strikes) I have only one site programmed as it is the only one I can hear.
Any thoughts? Thanks
RMason
Mississippi / Colorado
It sounds like Close Call or one of the priority modes might be turned on. Each of these will cause interruptions in the received signal. Check to see if you have any of these turned on:
Priority Scan
Close Call
Weather Alert Priority
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Is the Weather Priority turn on? That would cause a drop out every few secs or so... Do you see WX in the bottom right hand corner of the display. Hit WX button to toggle through the available options. Good luck!
Falcon9h
