Another EZ Scan problem
kruser
Well Known Member
W St Louis Cnty, MO
I can no longer 'Save Current Configuration To Archive'.
Is anyone else having this problem?
Close and reopen EZScan and then try. I've seen this problem for a long time but only after I've been working in the program for a while does it happen.
Doing what I said above always allows me to do the save. Hopefully this will work for you as well.
eyes00only
Denver Colorado
That seems to work. Thanks.
kruser
Well Known Member
W St Louis Cnty, MO
Glad that worked. I think this one has affected me since the very early days of the EZScan application back when GRE was still doing things.
I never really see anyone reporting it though so maybe it just affects a select few.
Ubbe
Stockholm, Sweden
I've had that problem a couple of times and I instead saved to a V-scanner folder, just to be sure that nothing was lost by restarting EZ-Scan. I haven't seen the problem since a year back and don't know the reason. Maybe the number of edits I did where greatly reduced after that and the chances of it happening again where then minimal.
/Ubbe
