Another IC-f5021 thread (help programming)
Stuckthrottle
Hello all,
I've tried different opc 1122u cables (unsure if the first was bad) as well as ver 2.3 and 3.4 of the CS f3020 / 5020 cloning software. When I select read or information on the sw I always get an "illegal information" dialog.
Any help is appreciated.
Thank you
wa1nic
Westfield, Ma
Is your radio new or used? Is it possible that a previous user set the password?
Also, have you tried all the possible COM ports? Check in Windows manager and see what COM port becomes active when you connect the radio to the PC with the programming cable. That is the COM port that you want to use.
Project25_MASTR
TX-COMU
Texas
Another possible problem...someone disable data on the CS when they last wrote the codeplug. Loosely translates to you can't read the radio (but you can write).
This was the problem with a F221 I bought a few years ago...solution was to go to the local Icom guy get a codeplug for a F121 and then dump it into my F221. Yes, different bands but the radio would accept it (VCO wouldn't lock of course. Don't know if that trick works with a 5021 (I'd be willing to send a 4021 codeplug).
BlueDevil
WA
Is it possible the screen/display/function keys have been locked? Unlock the function keys and give that a shot.
Cheers,
Brandon
Stuckthrottle
It is used. I know the original owner and he told me the distributor he bought it from so I shot them an email seeking advice. Yes, I can see the COM port being populated (COM2) when I plug the cable in.
Thanks for the help.
Stuckthrottle
Is there a risk of "bricking" the 5021 with a 4021 codeplug? If you can pm the 4021 I'd like to give it a shot.
Thank you.
Stuckthrottle
Ok, I feel silly now. I disassembled the dash and pulled the radio to verify the model number. It turned out to be an IC-F121 (which looks identical to the aforementioned).
Bought the proper software (CS-F100) and it worked like a charm. Thanks everyone for your help,
Cheers.
BlueDevil
WA
Glad to hear it worked. Those units look a lot alike!
