another newbee
m1a
eagleville TN
hello just getting started I have a pro 84 from radio shack. It seems ok have had it for a year can pull in the only code i have from 25 or so miles. looking for codes and entering good ones are hit or miss mostly miss. Any help would be apreciated getting frustrated. Anything in the middle tn. williamson, rutherford co area would be great.
thaks.
m1a
eagleville TN
thanks for the info just got one from the list that works. love using the scanner but i know that i want to upgrade what has good range and is user friendly
rvictor
Milwaukee, WI
m1a,
The two links in the above posts should give you a number of choices. Unfortunately, however, you won't be able to listen to the trunked systems that are shown on those pages with your present scanner.
Dick
loumaag
Silent Key - Aug 2014
Katy, TX
Let me also welcome you to the site.
In reference to your question quoted above; range has little to do with the scanner and everything to do with the system you are trying to listen to. I am sure that some scanners have better receivers than others, but generally they are all about the same; that said, what you need for your area could better be answered by asking in the Tennessee forum where some of the locals can give you local advice and examples of what they use. You will probably find someone who may not live too far from you who can give you specific advice for your immediate area.
qlajlu
Silent Key
Kearns, Utah
thaks.
Welcome to RR.com, m1a!​
You have come to the right Web site for help. Although your scanner has been a good unit in the past, in today's radio environment it is a little deficient to do much more than what you are already doing with it. I would suggest you consider upgrading to a more robust scanner, especially one that can handle trunked systems.
I also suggest you post in the Tennessee Radio Discussion Forum for suggestions and help. Since they are local to the area, the folks on that forum would be able to give you much better advice.
Again, welcome.
