Another question on Sentinel Software
ttkoestner
I have recently purchased a Uniden 436 scanner and I'm slowly figuring it out. Awesome, powerful scanner
I've made some favorite lists and have been experimenting with what works best for me.
What I'm most happy with is the standard download of frequencies that comes from inputting the zipcode. There are a few that I don't want on that list though. I'm trying to read from scanner to Sentinel so I can see all the frequencies on my computer so I can delete those I don't want.
When I read from scanner to Sentinel, it seems like it downloads but I can't seem to find the file so I can modify it. Any ideas? Thanks Tom
n1chu
Farmington, Connecticut
Sounds like you have the scanner loaded up. You can delete what you don’t want on the scanner (Without connecting you the computer and Edit that way. Then load what you have saved into Sentenel.
hiegtx
Dallas, TX
Since you are, apparently, scanning using the main database and your location, there is no "file" being downloaded for you to review. However, you can approximate the list in either the scanner, or in Sentinel.
On the scanner:
First, make sure that you have the correct location set, and also review &/or update the range.
(For an explanation as to how range works, see How it Works: Location, Location, Location )
You apparently already have the Full Database enabled. If not, enable it entering the Menu and selecting Set Scan Selection
At the next screen, Set Lists to Monitor, make sure that Full Database is set to On. You can toggle it on or off by pressing the E key when that line is highlighted.
Once you have set that on (or verified that it was already on), press Menu to back up one screen.
Scroll to Set Nationwide Systems and press E to select Select Nationwide Systems
On the Select Nationwide Systems screen, you'll see various categories that are not necessarily unique to any one state. Scroll down through the list, and use the E key to enable, or disable, various Nationwide systems. (Some of these may be ones that you are wanting to exclude from scanning.)
83263
Once you've made your selections, press Menu twice to get back to the initial menu screen
83264
Scroll down & select Manage Favorites
At the next screen, select New Favorites List
83266
At the next screen, scroll down until you see Add Current dB Channels
83267
Select that. You'll get a prompt to confirm you want to do that.
This will then create a Favorites list based on your location, range, and service type selections. In other words, a list created with what you are scanning when using location and just the main database. The scanner will give it a default name, such as FAVORITES 0 or Favorites 1. You can edit the name to something else.
Now, you can read that back into Sentinel, and edit however you wish. In your Profile (in Sentinel), change your scan selection to download and monitor the new Favorites list instead of the full database. You can set the new list to use Location Control, either by editing the list in Sentinel to make that change, or changing it once downloaded to the scanner.
If what you want to change is really just cutting out some of the Nationwide Systems, you can do just that on the scanner itself, without creating a Favorites list.
You can also partially duplicate this process in Sentinel. Set your Location, Range, and Service Types, then choose Add Channels on Range... from the drop-down Edit Menu.
83268
However, creating this in Sentinel, you do not have the option to specifically exclude any of the Nationwide Systems. You could, however, delete (or avoid) the unwanted ones before writing the list to the scanner.
ttkoestner
Steve THANK-YOU for all of your knowledge and help. You definitely have a way of making complex things easy to understand. Thanks, Tom
