prcguy
If your using six of the large 1/2" ID 31 mix beads you might have between 600 and 900 ohms of impedance on the higher bands and a really good common mode choke will have 10-15X that. In attenuation speak you might have up to 15-18dB of common mode attenuation and there are chokes out there that exceed 40dB.
Thank you prcguy. That is the information I needed to expand upon for upcoming projects. I use six mix 31 beads on LMR-400 coax for the hexbeam. Now and I am curious if things can be improved there. Not that I am noticing any problems now. For my inverted V OCF I have a 150' run of LMR-400. I have not observed a difference with or without an RF choke on that. Also, thank you for the balun testing information as well. I have a few to test.
Thank you Fred for those part numbers and details. That saved me plenty of time and effort.
At this point in the hobby I am at 1.2GHz and down. VHF/UHF contesting allows me to analyze different antennas at different locations via QSO. Beacons are also quite helpful.
