antenna element diameter ?
sgt795
Looking to construct a 6m dipole, is there any advantage to using larger diameter materials, 1/2 copper pipe vs # 14 wire?
Looking for electrical considerations more than the mechanical aspects.
Dave/N2NWS
KE5MC
Lewisville, TX
Theory is antenna element diameter effects tuned antenna bandwidth. In practice the change is very small and of little practical advantage.
Mike
wyShack
Campbell County, Wyoming
I have used 1/2 inch copper pipe with a CPVC tee as the center insulator. I just use two machine screws to make a connection to the pipes from coax. I have found I get a bit more bandwidth with the pipe. If you use another chunk of PVC as a 'mast' a dipole made from pipe is rotatable. I turn mine by hand and then tighten the clamps back down. Changing the direction allows you to point the antenna every once in a while which may get you a few more grid squares -or point at the magnetic pole for aurora.
6 is a fun band.
73
RFI-EMI-GUY
Mike
It explains why wrapping rabbit ears with tinfoil yields a better picture!
