Antenna ID
KD2DXF
Nobody
Anytown, USA
Saw this on a truck in a parking lot. Mag mount. Looked in the cab quick but couldn't see a visible radio. Cell booster maybe?
I think you may be correct. Kinda looks like I've seen for a Wilson amp.
madrabbitt
NM
Wilson brand. Cant tell from the pic if its the newer or older style, but its most likely a cell amp kit.
Project25_MASTR
Monitoring
Texas
Wilson dual band. See a lot of those out here with the coax running back into the cab via the 3rd brake light which is something I just don't understand.
If you didn't see a cradle in there, then there is probably a small panel antenna in the headliner to provide a boost to anyone in the vehicle.
madrabbitt
NM
how do you not understand it?
the coax needs to get to the booster somehow. Running it thru the third brake light is an easy way of doing it, provided you do it right.
Project25_MASTR
Monitoring
Texas
Doing it right consists of removing the third brake light, installing an NMO mount just above it and closing everything up. If you are going to take the trouble of routing the coax that way, it doesn't make any sense not to go with a permanent mount.
madrabbitt
NM
1. In a leased vehicle situation, they may be penalized for drilling holes.
Although, you're in lubbock, so I bet a bunch of the ones you see are oil/gas which probably have 1 or 2 NMO mounts anyway, so they "should" do it with an NMO... but chances are they buy the wilson kits in bulk from wilson and go with whats in the box VS ordering a NMO version.
2. The "right" way of running thru the third brake light is to order a second gasket (provided that the original has one) and notching it for the cable, then putting it all together, or using clear silicone to make a gasket with a notch for the cable. That way the cable isnt pinched by reinstalling the third brake light. Also, ideally, you should run the cable thru the bottom of the third brake, not the top, so you can be assured that rain wouldnt get thru.
Cant do that with thicker coax, but the RJ174 on the mag mount wilson antennas, or the thin cable on a mag mount XM radio antenna can easily be run this way. Short install time, short deinstall time without permanent modifications.
Just because you or I NMO everything, that doesnt mean that is the correct way for the entire world to do it.
