Antenna question.
AES-256-Encryption
"Be the change we need"
I have 2 mobile radios UHF/VHF. One DMR one analog. I need both on the antenna but only the VHF one is. Is the best way to 2 diamond X50 antennas? I currently use an old TV antenna that has UHF VHF. But I would love some recommendations THANKS!
XPR4550 / CDM1550-LS+
with that would Low be one of the radios and High be the other radio? then ant would just be going to the ant
A diplexer like he recommended will have two ports, one will be for VHF, the other for UHF. There's a "common" port that will feed your dual band antenna. The diplexer isolates the two radios from each other sufficiently that they'll work independently, even when one/both is transmitting.
AES-256-Encryption
Ill get that ordered thank you
