Antenna Questions
GrayJeep
N. Colo.
The firestik is setup to "look" (to the radio) like it's 102" long. It needs a ground plane of adequate size to work right.
K9DWB
Waynesboro, PA, USA
I had a 102" antenna mounted with a large coil spring mounted on the right rear of my car to run a CB. I'd bought all the parts at Radio Shack when they had the answers to our questions. It did quite well as a mobile setup. So yes, ground plane makes a big difference in making or breaking it.
PS my poor car looked like a Remote Control car refugee.
K4EET
Chaplain
Severn, Maryland, USA
Can you run more power to an antenna than it’s Rated for?
Sure. You just run the risk of the antenna failing and depending on how it fails, and depending on how much or how little protection the transmitter/receiver/radio system has built in to it, it may take other things with it too.
