ANTENNA QUESTTION
Chuckjen17
ANY SUGGESTIONS ON UPGRADING STOCK ANTENNA ON WHISTLER WS 1040.. JUST GOT IT AND WANT BETTER RECEPTION
WB9YBM
Base or portable? For portable I've had good luck with the telescopic whip that Radio Shack sells.
jaspence
Michigan
If you get a larger antenna that mounts on the radio, be aware that the extra stress may cause problems with the BNC. Keep the BNC tightened and if reception suddenly stops, a broken solder joint is the first thing to check.
