I have found the Remtronix to be the best for distant systems. For close-by simulcast systems, I have had success with the Comet Miracle Baby. But the most important factor for me has been the SDR and software. SDR-Trunk and SDRPlay RSP1b solved my simulcast problems. What software and hardware are you using?I have tried a Remtronix antenna for my local P25 the tower is 4 miles and the Remtronix always dropped signal looking for a small that would work
Perhaps the same frequencies the OP mentioned in this post as coming in 0 to 3 bars?and what freqs were dropping? 150, 400,7/800?
PCTEL 18 element 16 dbi
800BRemtronix makes many different antennas. Which model antenna did you try, and what freqs were dropping? 150, 400,7/800?
I tried Sdr trunk, unitrunker and DSDplusI have found the Remtronix to be the best for distant systems. For close-by simulcast systems, I have had success with the Comet Miracle Baby. But the most important factor for me has been the SDR and software. SDR-Trunk and SDRPlay RSP1b solved my simulcast problems. What software and hardware are you using?
851 to 860Remtronix makes many different antennas. Which model antenna did you try, and what freqs were dropping? 150, 400,7/800?
This is another sdrI am using at the moment a 4 element Yagi that's indoors. I am on Long Island and can get systems from NYC NJ CT and NJ using rtl dongles.
You mentioned using a PCTEL 18 element 16 dbi and were still having issues. You say the 800b is drops signals from 4 miles away.
4 questions.
How were you hooking the PCTEL and the 800b to your dongle?
Where is the antenna mounted?
How good is the coax and what is it? rg58, rg6 etc?
Are you using any splitters to use 1 antenna on rtl dongles and scanners?
What about the SDR? What are you using? Is the system you are trying to monitor a simulcast system?I tried Sdr trunk, unitrunker and DSDplus
huh?What about the SDR?
I’m in the middle of a P25 simulcast system with almost 20 towers. In my testing of various software and hardware, the SDRPlay RSP1B with SDR-Trunk (nightly build) along with the comet miracle baby completely eliminates simulcast distortion. It outperforms even my SDS100. The Airspy R2 is good, but still has some distortion. I have one of my SDRPlays dedicated to that system since the settings have to be exact to eliminate the distortion.huh?
Sdrtrunk, Unitrunker DSDPlus, all an sdr and handle simulcast quite nice.
I run a rem 800 on mine and can reach out 30+ miles from in my house. Check your connects. If running sma to bnc, ect ect you may have a bad connection point. I had it happen to me. Try to keep your connections as simple as possible and "clean". If you bought jumpers, are they quality? Simple little things like that make a BIG difference.I tried a Rtl-Sdr and a Airspy R2 could the antenna have to much gain the antenna covers 806 to 896 does that mean the most gain will be at 851
