Antenna
lowboy654
DB Admin Member
Northwest, WA
Antenna's, whats everyone use and have I myself a a big pile of them Fire sticks, Radio Shack junk, Pro comm spider, valor ProAm PMM3B and a few RS 800's. and more.
For my 396T, I bought the RS 800 mhz antenna, but I hate having to use adapters (from SMA types.)
I can highly recommend the Antenex antennas from Scannermasters.com. I'm using their SMA type.
http://www.scannermaster.com/Portable_Antennas_s/27.htm
I have both the full size and 1/4 wave low profile. The LP works surprisingly well for it's size. The full size is used when I don't care about its height or looks.
I use the LP about 98% of the time.
K7SCH
Buckley, WA
800 MHz Antenna
I have multiple handheld scanners and I listen to 800 trunked frequencies, and the antenna that I use is the RS 800MHz antenna (http://www.radioshack.com/product/index.jsp?productId=2102525) but it seems that I do not always catch the entire transmissions; it will drop off or will pick up mid way in the transmission, and usually they come across scratchy. I am less than 5 miles away from the dispatch, so I thought they would come in clear and on point. I do not know if that is from the scanner (pro-97) or the antenna (RS 800MHz). If anyone has any good recommendations or experience for a handheld 800 antenna it would be cool the hear.
AtomicTaco
Who's dispatch are you trying to pick up? If you're using 851.8125 for KC/VC be aware that the closest tower is on 360th on Federal Way. There's also a repeater on Grass Mountain, but I can't remember if that simulcasts everything. I don't know much about Enumclaw's dispatch, but if I remember correctly, they're VHF.
jrw14493
Since Yakima County is 99.91% VHF I went to radio shack and bought their 20-176 $26 antenna for my PRO-2055. Drilled a hole through my wall into the attic space to run the wire and mounted the antenna on a rafter and it works really, really well. I think the key was using anything other then the antenna that came with the scanner.
For my Kenwood portables I'm using the KRA-26 Kenwood antenna and just the generic scanner antenna for my PRO-97.
In my truck for my scanner, I'm using a Maxrad quarterwave and some sort of tuneable, NMO mount CB antenna. The holes in the roof hurt, but the reception is great. Pictures are available if anyone wants one.
JRW,
I have the 20-043 model (RS Discone) and it works really good for a base scanner. I use it as my main scanner antenna. It's mounted on the roof but I wish I had it up another 30ft or so.
I recently put up a DPD 700-1000mhz Log Periodic directional and that's my main public safety (866mhz) trunking antenna. It helps make up for my distance to the Tacoma/Puyallup and SERS trunks.
-Nick
