Antenna
rheroff
Minnesota
Wondering what is a better antenna to use on the homepatrol 1 A Spectrumforce Wideband Antenna with Mag Mount and SMA, or the original antenna that come with the homepatrol 1 ?
popnokick
Northeast PA
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 6_1_2 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10B146 Safari/8536.25)
Most any antenna is better than the one that came with it. But isn't the SpectrumForce a mobile antenna? You're comparing apples to oranges.
blue5011
Faribault County, MN
The height of any antenna you use is more important than the style/ make/ model. I use a cheap R/S generic scanner antenna (@35 feet above the ground) R/G-58 coax. I am happy w/ the results.
Richmond, VA
I would think the mag mount antenna would perform better if it were grounded properly. Using it mounted on your car would be a natural ground, or if using it at home, place it on a metal file cabinet or a flat sheet of metal to achieve a ground plane.
As others have mentioned, neither option compares to an outdoor multiband antenna.
Sent from my cm_tenderloin
MK
I use an HP-1 with a RadioShack mag mount and SMA. It works far better than the small antenna that comes with the scanner.
JASII
Memory Capacity
As already pointed out, low loss feed line is critical at 800 mHz. I use 9913, but there is better coaxial cable available. Unfortunately, I think some people just go to Radio Shack because there are a bunch of them around. So, they end up going t here and getting the best that Radio Shack has in store. That is often RG-8 or even RG-58!
