Any idea where to listen to Nicor gas in central illinois?
gewecke
Banned
Illinois
Nope,it's not listed in the DB correctly either,as I've searched the entire 451 mhz. range.
any ideas? Anybody? :confused:
Thanks. :)
n9zas
FFPM571
Nashvillle
They use mostly MDC's in the trucks on the UHF freqs to dispatch service calls. Most voice communications are done over NEXTEL
shadcall
Ormond Beach, FL
Did you try the FCC Data Base? Here is a link. Not sure this is the Nicor Gas you are looking for. Click on each current license and when that loads click on frequencies tab.
License Search - Search Results.
Here is the link for the home page. On the left scroll down and click on license search. Then choose name from the drop down box and type in the name, for example Nicor Gas.
FCC Universal Licensing System (ULS): ULS Home
Shadcall (former Illinois resident)
Pro 106 Pro 163 Pro 164 Pro 62 Pro 2027
Antennacraft ST2
DX-390
gewecke
Banned
Illinois
Antennacraft ST2
DX-390
IF you read my post, I checked the DB but thanks anyway.
n9zas
gewecke
Banned
Illinois
Thanks, I wasn't aware that they were using nextels.
It figures!
n9zas
shadcall
Ormond Beach, FL
Sorry, when you said you checked the DB, I assumed you were talking about the RR database.
If you have a HH scanner that has close call or signal stalker on it you might be able to find any frequencies they are using if you are near their base or one of their trucks.
Shadcall
Violation
Near KDNV
Nicor Central Illinois freq.
Back in the 60's and 70's "Northern Illinois Gas" could be found on 451.225 in Champaign County. If memory serves me correct (?), they were dispatched out of Paxton or Gilman....not sure about that, but somewhere up north........PW
gewecke
Banned
Illinois
I saw a nicor service truck the other day which still had the laird low pro uhf antennas on it,but on searching when I got home from work all I heard in the entire 451 mhz. range was mostly data. So they must be using nextels in this area.
Thanks everybody, for your input! :)
n9zas
