Any radio with timer recording?
clovisb31
Sanger,Ca.
I need to replace a really long in the tooth Ccrane witness recorder. Are there any portable radios out there that offer
a recording function? Specifically I need a timer (on/off times). All I'm finding so far are radios that support recording but you have to be present to
actually start the recording function manually, then also turn it off when done. Basically useless.
Too bad the Ccrane witness was discontinued long ago. If they came up with a new model they would make a Billion dollars.
kdeke
Usa
Sdrplay's nRSP-ST has a recording schedule functionality for wav or IQ. Once set it can record without pc.
clovisb31
Sanger,Ca.
Pretty complicated and expensive solution to what I need. I guess I should have mentioned portability and
recording to an SD type format. I don't think anything like that exists out there at this time.
But thank you anyway.
