jeff777
Hello,
I've been getting my feet wet so-to-speak with the RTL-SDR v3 dongle, and I've noticed that if I try to monitor any low frequencies in the area of shortwave and 80m amateur radio bands, I get a lot of noise that prevents me from being able to listen to them (I can't even pick up WWV on it because of the noise). Not knowing if the noise was coming mainly from my laptop or the area that I'm in, during a trip nearby the ocean this past weekend, I tried out this same setup there and noticed the same issue of noise. In case the question comes up, I'm using the SDR# app, and it's configured for Q branch sampling so that I can monitor the lower frequencies with the RTL-SDR v3.
In comparison, I can monitor shortwave fairly well at my location with the C. Crane Skywave SSB Radio, using its telescoping antenna as well as with a reel antenna. So I can pickup stations on there that I'm unable to pick up with the RTL-SDR v3 setup (utilized also with a telescoping antenna and a reel antenna).
Are there any recommended SDRs that are good with shortwave reception that can also filter out noise fairly well? Also, is there anything recommended that can be done with the RTL-SDR v3 that can help filter out the noise at the lower frequencies, or would a different SDR be recommended for those frequencies?
Thanks.
Thanks.
