Anytone Anytone 778uv Mobile
popnokick
Northeast PA
When you reach the homepage on nearly any manufacturer's or radio technical website there are typically links to more information, products, tech info, etc. Clicking on those links will take you further into the site and provide more info (e.g. list of products, specifications, application notes, etc). https://en.wikipedia.org/wiki/Web_navigation
popnokick
Northeast PA
It should. I didn't look specifically at your AnyTone radio, but most FM and DMR mobile rigs use that OEM-T connector.
tadpole207
NC/SC
thanks. I was mostly concerned about the gauge on the back of the power supply posts. I know you said they were called 5 way binding posts, but i could not find the size to help estimate the size of the gauge for the ring adapter.
Powerwerx said they will fit-
The OEM-T connector is compatible with most FM radios and the 1/4" ring terminals easily connect to the rear of a Powerwerx SS-30DV or other power supply.
So by seeing the image, i am pretty sure they fit the binding post. Not a big deal but i can't find the gauge listed and got frustrated, and then figured out 1/4 inch meant the size of the terminal, and my stupid ass forgot to calculate the gauge from that.
Appreciate all the help.
KE5MC
Lewisville, TX
Not to derail, but a couple of points not mentioned. The plastic cap nuts can be difficult to remove. Spilt rings might be better. Often on banana jacks there is a hole for a wire or wire terminal pin that the plastic cap nut is screwed down on. Attached is a picture of a DIY pig-tail I have on an older small Radio Shack PS with the positive wire terminal pin removed for picture. Click for bigger picture.
Mike
