Anytone Anytone 878UV plus Band Error Problem
bdc451cop
I recently purchased a Anytone 878UV Plus radio, when I went to program the radio with the CPS software, of course I got the "band error" message I look on Bridgecomm website to find out on how to fix this issues. Bridgecomm says to hold down the PTT button and the #1 button at the same and turn on the radio, the radio will go into "Test Mode" and you can rotate the channel select knob from band 0010 to 0000. My problem is the radio will not go into test mode to switch the band mode. My question is there something I'm not doing to get this radio into test mode?
KD8DVR
Elitist Ham
Columbus, Ohio
The latest Anytones have eliminated the PTT+1 option. TassieJay's answer above includes a link to download the software required to do the band change.
NWI_Scanner_Guy
Dyer, IN
Not all of them apparently. I got my 868uv this past Wednesday (with the most current firmware), and I got the 'band error' message. I found the PTT + 1 method via Google and it worked. I got the codeplug downloaded to the radio and I've been enjoying the heck out of it ever since.
Skypilot007
Medford, NJ
Probably worked because you have an 868, they haven't done a firmware update on those in quite a while.
U00V118
Oswego, IL
Have any of you had trouble getting to the link that TassieJay added? Just got my 878UV and getting band error messages however i am unable to get the radio into Test mode using the PTT + 1 method. Contacted the support line from where i purchased the radio and they pretty much just said "keep trying." Been trying for two days now. I found this thread however unable to open the link. Says the page is not found. Does anyone have the software that they could possibly email me?
rgchristy
Delco, PA
I'm getting page not found, too.
Hit_Factor
Saint Joseph, MI
AT_Options works with the AT-D878UVII Plus. Just received a pair of these new model HTs and set them to Mode 14 for RX/TX 136-174, 220-225, and 400-520. Firmware is 2.01b.
