Hello everyone,
I am interested in the Anytone AT-D168UV radio. I would use it for personal use (for local listening to conversations or talking to radio amateurs in the Ljubljana area), if possible. The user.pdf file (missing) (there are useful talkgroups inside) which I used to help myself. I installed the D168UV_Setup_1.05.exe software on my computer and looked at the options. There are many options and not all of them are easy. The user.pdf file (missing) contains talkgroups for the whole world and can be imported as user.csv (missing) into the "Digital Contact List". Source for user.csv: Database .
Talkgroups TG-293 (Slovenia):
brandmeister.network
Repeaters in Slovenia:
Ljubljana - Bezigrad, SI: Ljubljana - Bezigrad 144.550000 S55VZR Slovenia Simplex Node
Mt. Krvavec - S55DKV: Ljubljana, Mt. Krvavec 438.475000 S55DKV Slovenia Repeater
Žagarski vrh (Ljubljana) , Slovenia: Žagarski vrh (Ljubljana) 438.550000 S55DZV Slovenia Repeater
Three repeaters near Ljubljana:
I have a few questions:
1. Is it necessary to have a license to purchase and use the Anytone AT-D168UV radio (I don't have one)?
2. If the screen is locked when the Anytone AT-D168UV radio is new and turned on, how do I unlock it?
3. Can you program the Anytone AT-D168UV radio for the Ljubljana and/or Slovenia area before purchase (does this make sense for Slovenia?)?
4. What is the DMR ID of the Anytone AT-D168UV radio and how do I obtain and enter it manually?
5. Do I need to enter the DMR ID of the Anytone AT-D168UV radio before purchase or do I have to generate it (how?) and enter it myself?
6. Does the DMR ID have to be registered and how is this done? Can you register a DMR ID? Link: Register .
7. Where can I get the contacts of everyone who uses the Anytone AT-D168UV radio? I use info.pdf (missing) and user.pdf (missing).
8. What is the range of the Anytone AT-D168UV radio in kilometers?
9. Is it worth buying the Anytone AT-D168UV radio or not?
10. What are the disadvantages and advantages of the Anytone AT-D168UV radio?
Conclusion: The Anytone AT-D168UV radio seems complicated to use. The best thing is that the package includes two antennas and two batteries. I like that it allows you to record conversations on analog frequencies as well as digital frequencies. The D168UV_Setup_1.05.exe software was easy to install on the computer. The problem occurs when installing all the parameters. The link Hoseline is also interesting, where we can listen to conversations.
Thank you.
Best regards!
Ptolemy
Talkgroup | BrandMeister
Thank you.
Best regards!
Ptolemy
