Anytone Anytone AT-D878UV and AT-D878UV Plus w/ Encryption
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
I have an older AT-D878UV that I bought from a friend (I think he used it like once) and just recently bought another one but with the Bluetooth option, so they are basically the same. Both have firmware v1.21 loaded on them as well as the Hardware version (1.00) and Radio Data version (1.00). They both have the same codeplug loaded on them as well (the BT model has those options set).
I set up a single simplex freq in DMR and and tried encryption. If I go under "Optional Settings, Other" and set encryption type to "common" and select Digital Encryption on the channel to 1. If I load both radios like this, they can encode/decode correctly.
If I change the encryption to AES under "Optional Settings, Other" and select an AES Digital Encryption key on the channel settings then write to both radios, the new radio will transmit and I can hear the encrypted traffic on the older radio. It sounds about the same on a scanner too. If I transmit on the older radio with the same codeplug and everything, it will only transit for a second and then stops.
Any ideas?
zerosix
Did you end up using a different mode, or did you only update the baseband?
jonwienke
More Info Coming Soon!
VA
Mode 0 enables 136-174 and 400-480.
Mode 14 enables 136-174, 220-225, and 400-512.
