AOR 5700D 2023
kdeke
Usa
When using SDR# are both USB cables and the IQ dongle required?
For SDR# you only need the two usb cables (one for remote and one for IQ data), no dongle.
The dongle is only needed to run the AOR supplied AR-IQ-III software
wb4sqi
Amelia, OH
Got it! Successfully installed all the AOR software and SDR# yesterday and finally got all of it to work. Only negative is neither package will allow me to change from ANT1 to ANT2, not sure yet what might be causing that. I'm using a 10 year old i5 laptop with 8gb memory as a temporary test bed so the processing power for the IQ portion is lacking but I can't see why neither package would allow me to change antennas.
kdeke
Usa
It seems to be a radio "feature"
Just checked, indeed ANT1 to ANT2/HF switching doesn't work on HF, however it should work higher than 25MHz.
(for me on VHF I was able to switch)...
If you read the manual (page 9, connecting an antenna), it seems that the antenna port functions are inversed when using I/Q (so with SDR#).
Normal case= standalone radio:
ANT1: 25MHz-3.7GHz
ANT2/HF: 9kHz-3.7GHz
IQ case (=SDR#/AR-IQ-III via IQ OUT) or IF case(using 10Mhz IF OUT):
ANT1: 9kHz-3.7GHz
ANT2/HF: 25MHz-3.7GHz
So, something to take into account when connecting antenna's..
wb4sqi
Amelia, OH
ANT1: 25MHz-3.7GHz
ANT1: 9kHz-3.7GHz
Amazing! Gotta wonder what the thinking is behind the code writers at AOR. Thanks for the tip.
Pzaz
London
Has anyone used the 5700 remotely using usb over Ethernet? I’ve almost got it to work but the software doesn’t see the radio but it goes into remote mode.
HE9JYP
Switzerland
Question for 5700D owners.
Does it decode the C4FM VW (improved voice) in addition to the classic DN. I saw that the next DV-1 firmware will accept VW decoding, which is not currently the case .
SigIntel8600
Communications Receiver Nut
Pine Barrens
Good question. A firmware update would be required. Radios would need to be sent to Japan for the firmware upgrade if and when it becomes available.
Pzaz
London
Hi I would like to have a gripe.
The backup fails more times than it works..WTF.
No update path except the path to Japan….WTF.
Memory editor…WTF.
ARIQ. Not worth bothering with.
on the other hand there’s nothing to compete with it on funtionality…unfortunately
Pzaz
London
After at least a year of looking and prevaricating, two days ago I managed to get hold of a used 5700 from Martin Lynch & Sons at a semi reasonable price. It was sold new in January this year so hoping the firmware is fairly up to date.
First impression is how heavy and solidly built it is. With my less than perfect eyesight and chunky fingers I like my radios to be even bigger with more buttons and controls readily available on the front but I’m pretty happy with it as it is. In operation it reminds me of the AR3000a while being much more substantial and a lot more versatile.
I was a little worried that my local light rail transport Tetra system was only producing occasional bursts of static and no voice transmissions, however a check with an Airspy on SDR# is now also giving no voice even though it is still not shown as encrypted. Is anyone having success with Tetra reception in the UK?
Looking forward to playing with Cyber Search on the Civil and MilItary airbands. In the meantime I’m very happy with the speed of normal search and will continue getting to grips with the user manual.
No usable TETRA down here Hertfordshire. I can hear some but encrypted.
Pzaz
London
London Underground share 390 -395MHz in the clear with Airwave, but you need to be near the rails or stations to hear them...
Not much chance of that then. Basically the TETRA side of these things is a waste of time in the UK so we are paying for something that doesn’t work in the UK. The only good thing is it covers DMR and the ham digital prtocols.
G7HID
Box 500 Slough UK
I was trying to be of help as you are not a million miles from a London Underground station :(
Pzaz
London
Thanks they didn’t bring the tube out this way nearest is Oakwood near Southgate north London, much too far. Im up the A10
RichardMorris
Fairfield Texas
I just took delivery of a brand new AR5700D direct from Japan via eBay (yokamonmarket). Total cost was $3792.00 delivered to my home in Fairfield Texas. I was concerned about the additional cost due to Pres Trump and his tariffs but I got lucky and ended up with no tariff cost at all. I ordered it on April 26, 2025 and got it May 17, 2025.
Firmware Version (using AR5700D editing software) is
Main_403AR D3N5A P403A
Has anyone come across better editing software? (The only programs I have are from AOR).
The AR-IQ-III program looks nice but I am guessing that AIRSPY might make it obsolete.
I also bought the SDR# hardware from AIRSPY but have yet to set it up.
Rick KG5IZF
AOR-262
@RichardMorris
I have within a few months had my 5700D upgraded to the latest Firmware. Mine reads:
Main_403A D4NCA P403B
Did you mistype when typing your Firmware? You write you have Main_403AR. According to the latest Firmware release sheet from AOR, there is no _403AR.
See attached file.
  • AR5700D firmware release notes.pdf
to2way
Toronto
Wow! So release notes do exist! Thanks for sharing! Now I know how old my FW really is!!!
