AOR AR-DV1
harryshute
Edmonton, Alberta, CANADA
no , I just save the memories...!but I can reproduce it for you if you like...?
No that's fine. From what I read unlike the firmware upgrades I've done before this one erases a number of memory items and they have to be restored using the methods in 5-3 of the manual once you save them on your SD card.
ve2mel
Saint-Pascal, Québec, Canada
I install again the 1512A and i made hard reset and re-program manually all my frequency... and all going fine now and the scan speed is fastest now...good job AOR...!
Eric VE2MEL
ve2mel
OK, I open my radio today and the probleme comme again, scann slowly... very slowly..! like sql open and when signal is present on busy channel a big buzz comme from the speaker...! and i'can't ear annything. I made only i simple reset , not memories and the scanner work perfecly, scann speed up and work great.
there was a probleme with the 1512A.
Eric VE2MEL
harryshute
1512A Problem
Eric VE2MEL
Oh that's not good. I haven't done mine yet but will watch for that and report in.
harryshute
Firmware Update hint
Eric VE2MEL
Eric I did my update today and may have an answer for you. At the end of the update process don't just turn off or close the radio as that's not enough. You must disconnect the power for 30 seconds and then reconnect.
harryshute
You may want to call AOR at 310-787-8615. You may want to back up your setting on the SD Card and try a full reset rather than just a system reset.
harryshute
harryshute
Your problem seems to be with 171.180 SQ Simplex A. Could they have gone digital rather than analog carrier squelch? On RR DB no CTCCS tone is shown for that frequency. Perhaps re-enter that frequency.
ve2mel
No, the probleme comme on eatch channel comming busy . in my video you see the problem on 171.180 but the probleme is on all chanel. I make a test for you , i delete the 171.180 and close the radio and open the scanne is very slowly and when the signal is present on anny chanel , a big buzz comme
n2pqq
Could the problem be coming from the radio
Below it or the item sitting on top of it ?
Try moving the radio .
WRGT54er
Germany
Hi All,
i have the same Problem with my brandnew DV1 Firmware 1512A: When I switched to AM/SSB/CW and
shutting down /Reboot the Radio I have a Noise like Eric`s DV1 has. Changing the Mode to FM and back to AM resolved the Problem. With the delivered Powersupply the Radio gets a little warm and the PS itselv gets hot. I tried a 2A PS, the Radio now stays cool but the Soundproblem is still alive.
reg
Joerg
hamradionl
Anyone have problems with the SQL level ?
In FM mode
SQL level set below 60 SCAN or SEARCH stops and not go FWD
when the SQL level shows 60 or above, than SCAN or SEARCH will go FWD again..
MStep
New York City
What Type of Squelch do you use ?...I think for best Results use the Level Squelch.
Might you able able to give a brief explanation of the different squelch types and what they are supposed to accomplish? The manual is not very clear in explaining the differences. Thank you.
WRGT54er
Germany
I think in the Manual on Page 27 the Types are very good described.
My Wishlist for the next Firmware Update: Fixing of the Bugs, Autorecording Function, Deleting Function of the recorded Files.
