APX 2500 David Clark
Hello, I am looking for the Pin out diagram of a Motorola APX 2500 20 Pin. I'm having issues finding a 20 pin map. This will be hooked into a David And Clark headset system so that setup map would be helpful also.
kf8yk
For the David Clark C3821 generic radio interface cord:
Red Mic High - XPR Pin 2
Yellow PTT High - XPR Pin 3
Green Audio High - XPR Pin 11
Blue PTT Low - XPR Pin 7
Black Audio Low - XPR Pin 7
White Mic Low - XPR Pin 7
Shield - XPR Pin 7
kf8yk
I should note that this provides a fixed receive level to the headset system, if you want the receive audio to follow the volume control or if the audio level is insufficient then connect the Audio High & Low wires across the radio speaker:
Green Audio High - XPR Pin 16
Black Audio Low - XPR Pin 1
The audio high/low inputs are transformer isolated so no concerns about the bridged audio amplifier in the radio.
