Apx 6000li shoulder mic adapted to PTT
Jbernard475
Hi everyone, I am new to this forum and im just getting started in radio electronics. I have a APX 6000Li shoulder mic that has the standard 12 pin accessory pinout connector on it. I was given a TCI push to talk with a broken accessory connector. I am trying to connect the PTT to the accessory connector that I cut from the mic. The problem I am running into is that I don't know the APX 6000Li pinout and which color wire correlates to which pin. I have tried every which way and have been unsuccessful with getting the PTT or audio to work with a headset. Does anyone know if this can even be done, or know which color wires need to be connected to get audio and the PTT to work. The pics below are the whole project and the cut ends.Thanks!
scfd4
Zip tie technician
PA
Have you already tried matching the wire colors together? I know one has more than the other but it would be a start. Here’s the pin out to the m7 connector but unfortunately it doesn’t tell what goes where as far as wire color.
Jbernard475
Thank you for the pin out! I have tried matching all the same colors and like colors and have had no luck.
Those connectors are sealed and are impossible to get a part without destroying them, or else I would take it apart slowly and match the wire color to the pin.
APX6k
You could use the Ohm meter function on a multi-meter, or the integrated continuity tester (if so equipped), to determine which wire is associated with which pin on the connector. As for compatibility between the headset and the accessory connector, I'm not sure on that. I believe there may be an audio preamplifier in the RSM that may not exist in the headset.
- J
hitechRadio
You could of bought a decent trbo headset on amazon for cheap, instead of hacking up that speaker mic.
