APX 6000XE Clear Alert Tone
bnb911
Hello all, have a question I'm hoping someone might be able to assist with. My jurisdiction is (FINALLY) moving to a trunked system later this year and we are in the prep stages right now...our radio vendor has reprogrammed all our radios to include the new system so that once it goes live, we will essentially switch to that zone and be operational.
That being said, I'm running into an issue with my department's portables. We have APX6000xe portables.....some are AN-series and some are the newer BN-series. The problem I'm having is thus far the "clear alert tone" on the BN-series radios has ceased to function. Prior to reprogramming, it worked just fine. I've checked the codeplug and "talk permit tone" is enabled as it should be....but for some reason it is only working on the older, AN-series portables.
Has anyone run into this and is there a way to correct it? I realize its a trivial issue in some respect, but I'd like to fix it if I can.
Thanks!!!
EDIT: forgot to mention, I'm tasked with maintaining all the radios for my department and am still learning some ins and outs....not trying to do anything to them that I'm not responsible for.....just looking for additional guidance as our vendor didn't really have an answer for this.
K2NEC
39A
Sounds like its codeplug specific to the AN's, have you tried reading the AN and BN and comparing side by side?
bnb911
Yes, I checked one of each and the same settings are showing in both. What's confusing to me is the tech from our radio vendor told me there are like 18 different versions of our department's codeplug due to when radios were purchased, what firmware they have, etc etc.....I don't mind telling you I'm a total novice in the realm of radio programming, but it sounds extremely odd to me....he's saying the codeplug differences are why, for example, we're running into an issue with radios programmed identically, literally minutes apart with the "same" codeplug, are ending up with differing button assignments, etc. To me this sounds like something that shouldn't be occurring since all the radios are the same model and have been given updated firmware/entitlements/etc.
In any case, it does seem that only the ANs are working with this.....just can't figure it out
n3obl
ØAES-1024
PA
Its best to get to a consistent firmware across the board. But also radios with different flash codes necessitate different codeplugs.
bnb911
I believe all the firmware has been updated, but I have run into different flash codes....forgive my ignorance, but is the flash code something that cannot be changed? I tried to pull the codeplug from one of the AN series radios and write it to the BN series just to see what would happen and CPS rejected it because of a differing flash code.
K2NEC
39A
The model numbers are different so I believe that's why it won't clone
Flash depends on whats ordered at the time. There's some tools online that can compare flash codes and tell you what features are enabled
