APX 7000 Encryption
zacabo
FL
I just purchased an APX 7000 UHF/VHF in an auction but, I do not know if an encryption algorithms on it. Does the APX have an encryption module like the XTS 5K or is it internal?
lskipper
SUMTER
Turn the radio on and within 10 seconds press the bottom side button ( quickly) 5 times. That will put the radio into service mode and it will scroll through all information about the radio, including the encryption algorithms, if they are in the radio. To clear the service mode, just turn the radio off and back on.
Hope this helps.
Sent from my iPad using Tapatalk
rbrtklamp2
Dupage County, Illinois
No the APX series radios do not use a removable encryption board or UCM they have a built in encryption board called a MACE. As long as the radio is legitimate and tagged, not a ALT or DEV radio it should have a MACE on board. You can load encryption algos onto the MACE but you have to find a two way shop or buy them direct from Motorola if you want to add algorithms to the radio. Im sure it will come with software ADP but the rest will have to be purchased and loaded onto the MACE by someone who has the means to do so. You cannot buy a UCM thats already loaded with algos and install it like you could with the 2500/5000 series radios. The MACE is built into the radios board and cannot be swapped or replaced. Hope this helps.
Sent from my SM-N910V using Tapatalk
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Knowing what the current flash/firmware/host/mace versions are will help other with providing advice to help you out.
