APX 8500 Base Station Antenna
estone4009
Philpot, KY
I have an APX 8500 base station that needs a 700/800 antenna. This is the only band currently in use. Can anyone recommend a simple indoor antenna setup to try as mouting.an antenna outdoors will be problamatic? Singal strength inside rhe building is decent.
estone4009
Philpot, KY
Trucked system and only transmitting a couple times a week. I will have to look into the transmit power options.
At work, in this sorts of applications, I just have them use a standard 800MHz 1/4 wave whip on a mag mount. That would get stuck on a file cabinet or window sill. Keep the power low if you do programming. Or, just make sure it's spaced away from the user.
This antenna:
This mount:
N4KVE
PALM BEACH, FLORIDA
I used to deliver cars to the HUGE car rental return building across from the Miami Airport. Basically a 4 story parking garage, in the office they had a radio on the counter with a magnetic antenna sitting on the radio. I had to laugh.
I had to laugh.
It drives the radio guy inside me nuts, but it works.
I -really- want to do an external antenna, but the cost/effort is beyond what they want to spend. Usually these installs are places where a portable works fine, but battery charging/replacement becomes more costly than just doing a mobile with a power supply.
N4KVE
PALM BEACH, FLORIDA
At least it works, & the radio operator’s face isn’t 6 inches from the antenna. At the Hertz garage, the coax was tightly coiled with the magnetic antenna on the radio which was sitting on the PS, & the radio operator‘s face less than a foot away. And this office was deep in the bowels of the parking structure, but by a window facing towards a concrete wall.
DeoVindice
P25 Underground
5150 Level
This gave me flashbacks to a plant control room radio I once used. Kenwood TK-980 with a magnetic car phone antenna stuck to a giant nut that probably came off a jaw crusher. The antenna was set on the exterior windowsill a few feet from the motor control panel. It did in fact work.
prcguy
If I can find four rotating coaxial joints I might move all my car antennas to the hub caps and drive that way.
FFPM571
Nashvillle
Laugh all you want.. It's common to do that We call it a control station and its set to 5 w . Businesses and airports do it as to not have to use a handheld radio and get lost. stolen or battery not charged.
FedFyrGuy
Hagerstown, Maryland
Relocated an 800Mhz control station for a medical lab company courier service one time. They had an 800Mhz mobile antenna on a mag mount affixed to a STOP sign above the drop ceiling. Apparently it worked for them.....
