APX conventional TPT?
billy2047
📶 🕨 Ø T₁ ÆS Ⱬ ⬜ ᴴ L |→| 𝅘𝅥 💾 🛰️ 🔋
OUT OF RANGE
Hi all,
i'm trying to program several APX8000s operating on encrypted conventional P25 mode.
I'm trying to get the radio to emit a TPT (tone doesn't have to be fancy and single short beep also works) while using encryption. (Users complaint no audible feedback when PTT button is pressed).
TX Cleart Alert tone doesn't work on encrypted conventional talkgroups so that is out of the equation.
Any suggestions would be appreciated
BB
bg5gnc
ZHEJIANG ,CHINA
In the encryption(emergency?) options, there is an option to sound when pressing ptt, which can meet your requirements
CHangen702
Henderson, NV
More for my knowledge than to actually use it. Has anyone setup a APX portable to use conventional TPT since they just added it to the newest firmware release? I did see in the release notes that it needs to be setup in a certain way vs just checking the box.
GTR8000
NY/NJ Database Guy
BEE00
Before everyone gets whacker happy thinking they can have the radio sound a TPT whenever they key up...it only works on P25 repeaters, and the radio must receive the hang time carrier (at least 1 full second) before it will actually sound the TPT, otherwise you get bonked. It does not work on analog repeaters or simplex.
CHangen702
Henderson, NV
That's exactly the answer I was looking for. Ill try it on my Quantar for giggles but I wanted to have clarification to what I already assumed it was.
nhfdcadet
GCT-1
New Hartford, Ct
well its here with version 31 firmware with some limitations. It only works on a repeater channel, not available on talkaround, and if you have the talk permit tone enabled on the astro personality, it will "bonk" you if you are out of range of the repeater, just like a trunked system.
KevinC
Other
Home
So you will transmit twice I'm guessing. Once to hear the hang time and the second to actually talk. Interesting.
gatekeep
FAIL 01/93
New York, NY
In testing the radio transmits a P25 TSDU; waits to hear the repeater come up with a TDU tail stream, and if it does gives positive TPT and begins normal conventional voice. If it doesn't detect the repeater come up with a TDU tail stream, you pretty much immediately get the negative TPT bonk.
GTR8000
NY/NJ Database Guy
BEE00
Negative, the radio detects the carrier....err while typing @gatekeep's post popped up. What he said lol. One PTT, just hold it down and wait, just like trunking.
gatekeep
FAIL 01/93
New York, NY
So you transmit twice. :p
Essentially yea, the radio will transmit twice (assuming a positive TDU tail) for a valid voice call.
EDIT: The radios operational procedure is identical to trunking really, when you hit the PTT; it'll transmit a voice grant request to the CC, wait for response, switch to the voice channel then begin transmitting. Difference here is, it transmits, and waits to hear the repeater come up with tail, then just transmit voice.
