APX APX CPS Conventional Personality, "Current" vs "Default"
sphyx42
Wisconsin
Hello All,
I'm having this issue with CPS 27.00.01 when trying to create new Conventional Personalities. My goal is to essentially copy/paste 6 new personalities with the same setups as the selected one to be re-named for each apparatus (this is for a reserve apparatus so that when swapped for a front-line rig, they can switch to the right profile and transmit as their normal rig with MDC IDs).
When I select the the personality in the Conventional Personality -> Table View, then select Current in the drop down and hit the "+", nothing happens. But when the dropdown is set to Default, it will add new blank personalities all day.
Is there a lock on the personalities somewhere that I need to uncheck for this to work? Or is there some software/hardware key lock I need to have loaded up?
Please let me know if you need more information to flesh out this problem, and hopefully solve it.
Thanks for your help!
GTR8000
NY/NJ Database Guy
BEE00
There was a bug in some of the more recent CPS releases that prevented cloning of personalities. I don't recall when it was fixed, but I just checked R29.00.03 and it works fine.
