APX APX E5 Control Head / APX 6500 Mobile
mmcguire6036
How do you set an E5 control head on an APX6500 to dark mode in CPS? Im having trouble finding where to change it? Do I need to set up a profile then set each channel to the profile? Is there a way to toggle this between light and dark mode for day/night operations between all channels?
Thanks!
Solution
Press and hold the light button on the head. This is a global setting, not selectable based on channel. You can also save Day/Night mode in Display settings
You can however set the channels to have a certain color, that is selectable in the Zone Channel Assignment
K2NEC
5F6
Solution
